astroinc New Member 23 Member For: 20y 11m 24d Posted 20/10/11 12:26 AM Share Posted 20/10/11 12:26 AM Hoping somebody might be able to help.This is the story so far:FG Auto had its first custom tune 6 weeks ago nothing fancy just a K&N Filter and 290 kw tune. The results were awesome, nice smooth loud spool and able to break traction on even light throttle. All going really well.2 weeks later the MIL on the dash was triggered. Not wanting to break anything I pulled over and flashed back to stock and called my tuner who advised it is likely to be the o2 sensor.So all good. When I tried flashing back to the tune the Xcal 3 failed to download and locked me out of the custom tune altogether. Tuner advised to flash back to stock then reload. I had a few voltage issues but managed to get it back to stock then back into the custom tune.Another 2 weeks went by and the MIL light came on, but this time I ignored it and it went away after a day. I also started to notice the spooling at low revs was less audible and the power was less impressive and I was no longer able to break traction even under WOT. I get a little bit of boost at the top end of the rev range or under load at 100km/h. It feels more like a NA engine and not much better in performance than the stock tune. The exhaust/ engine noise is also a bit louder. I have also noticed each time I park the car the fan comes on nearly every time now.Over the last 2 weeks I have changed my fuel to rule out a bad batch, I have checked the hoses that I could see and everything seems to be still attached, I would tighten the clamps but they have changed the clamp type from the BA and I can't work out how to tighten them.Any ideas on what it could be would be appreciated. Link to comment Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 14y 7m 25d Gender: Male Posted 20/10/11 12:45 AM Share Posted 20/10/11 12:45 AM Boost leak, either hook up a boost gauge, or go through ALL of the connections on by one, including all of the vacum lines... Link to comment Share on other sites More sharing options...
astroinc New Member 23 Member For: 20y 11m 24d Posted 20/10/11 01:13 AM Author Share Posted 20/10/11 01:13 AM Hi Tobey,How do you tighten the stock clamps, or just ditch em and get some better ones? The Vacuum line is the one from the manifold to the BOV or is there another - sorry I am a newbie at this stuff. Link to comment Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 14y 7m 25d Gender: Male Posted 20/10/11 02:24 AM Share Posted 20/10/11 02:24 AM Yea, it may pay to ditch the ford ones. I believe they are they are 'blind' ones where the head snaps off when they are at the right tension.Also, there is a fault with the rubber joiner on the FG's that it splits where the pipe goes into the throttle body. Check there are no cracks... Link to comment Share on other sites More sharing options...
MurdoK Donating Members 719 Member For: 14y 8m 9d Gender: Male Location: Perth,WA Posted 20/10/11 04:37 AM Share Posted 20/10/11 04:37 AM Heatsoak? You pumping a lot of power through the standard intercooler.Would explain the thermo fans coming on when you stop. Link to comment Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 13y 7m 22d Gender: Male Location: Yeppoon qld Posted 20/10/11 05:11 AM Share Posted 20/10/11 05:11 AM The stock clamps have a cover over the hex head. Pull then off with a pair of pliers. With the increased boost it is a good idea to replace the stock pipes anyway. Is it a standard cat? If not the tuner should've sorted out the o2 sensor when doing the tune. Or like said above heat soak with a stock cooler. Link to comment Share on other sites More sharing options...
sambo29 Member 58 Member For: 13y 8m 16d Gender: Male Posted 20/10/11 07:30 AM Share Posted 20/10/11 07:30 AM Hey mate was just wondering how much boost was being run? And the torque figure you got with this custom tune?..Thanks sam Link to comment Share on other sites More sharing options...
f6mark Member 2,908 Member For: 14y 16d Gender: Male Posted 20/10/11 10:42 AM Share Posted 20/10/11 10:42 AM who tune it mate.???? Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 1m 12d Gender: Male Posted 20/10/11 09:18 PM Share Posted 20/10/11 09:18 PM fans are supposed to come on after u shut down the car. check your ic pipes. Link to comment Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 17y 11m 24d Gender: Male Location: Gladstone, Queensland Posted 23/10/11 10:21 AM Share Posted 23/10/11 10:21 AM Check for leaks like the boys already said, but a good idea would be to actually use the Xcal to check for DTC's It will tell you exactly what is triggering the MIL. Link to comment Share on other sites More sharing options...
