sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 5m 23d Gender: Male Location: Far north queensland Posted 19/10/11 05:15 AM Share Posted 19/10/11 05:15 AM yep, only a good option if you have bent a rod. Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151262 Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 14y 10d Gender: Male Location: Gold Coast Posted 19/10/11 08:11 AM Author Share Posted 19/10/11 08:11 AM Just out of interest ,What makes the compression higher in LPG/ petrol engines? Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151327 Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 17y 2m 7d Gender: Male Location: Sydney Posted 19/10/11 09:08 AM Share Posted 19/10/11 09:08 AM (edited) On 19/10/2011 at 8:11 AM, Gasman said: Just out of interest ,What makes the compression higher in LPG/ petrol engines?Mainly the piston used which would be flatter then a turbo piston, also due to the higher octane rating in LPG the engine can then have a higher comp!And with higer comp you can yeild better mechanical energy/power!As turbo and supercharged motors compress the Air and Fuel prior to it entering the chamber the comp does not need to be as high as a NA application and typically have CR's of less then 10.5:1! With out taxis being anywhere from 8.5 - 9.0:1! Edited 19/10/11 09:10 AM by Vevapower Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151363 Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 17y 2m 7d Gender: Male Location: Sydney Posted 19/10/11 09:09 AM Share Posted 19/10/11 09:09 AM (edited) Edited 19/10/11 09:10 AM by Vevapower Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151364 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 5m 23d Gender: Male Location: Far north queensland Posted 19/10/11 09:55 AM Share Posted 19/10/11 09:55 AM eGAS engine possibly able to run boosted and e85? Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151397 Share on other sites More sharing options...
joe@cms Member 129 Member For: 15y 10m 2d Gender: Male Posted 19/10/11 09:38 PM Share Posted 19/10/11 09:38 PM ok if you are on a budget the egas FG is perfect better rods & pistons than the n/a version, & on e85 or caltex flex there will be no issue with tuning....... with the right combo as we did one we've taken one well over to 350rwkw & runs perfectly also having more comp has more low down torque whitch feels like a worked v8................. its all in the tunecheersjoe Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151495 Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 14y 10d Gender: Male Location: Gold Coast Posted 20/10/11 05:51 AM Author Share Posted 20/10/11 05:51 AM I have heard of people using decompression Gaskets. can this be used on an LPG engine ?looks like the BA MKII motor with 87k on it is going in for just over 5K. Lee will check the tune to make sure it is safe and if not im up for an xcal and a tune. Anyone got a spare xcal 3 lyin around? Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151654 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 5m 27d Gender: Male Posted 20/10/11 05:55 AM Share Posted 20/10/11 05:55 AM Why not a new short motor from ford? $2900 for a fg short, if heads ok then that might be the way to go. You can still get BF MK2 short motors for same price and bolt straight in. With FG short there's a couple of small things to do to fit it. Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151655 Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 14y 10d Gender: Male Location: Gold Coast Posted 20/10/11 06:53 AM Author Share Posted 20/10/11 06:53 AM (edited) Well my head probably isnt the best ,There would be labour etc involved in getting the head checked and machined. Would end up costing more again, also its more cost effective to buy an F6 short. Edited 20/10/11 06:54 AM by Gasman Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1151684 Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 14y 10d Gender: Male Location: Gold Coast Posted 24/10/11 09:55 AM Author Share Posted 24/10/11 09:55 AM Anyone know much about NPC flywheels? Apparently my BA was found to have one fitted after the donk was pulled. Not sure on the clutch yet but it is very heavy. My Bro inlaw had an FPV GTP (BF I think) and my clutch is much harder to push in. Link to comment https://www.fordxr6turbo.com/forum/topic/77424-need-an-engine/page/2/#findComment-1153269 Share on other sites More sharing options...
