Ninka Donating Members 1,850 Member For: 22y 4m 15d Gender: Male Location: Perth, WA Posted 29/05/12 07:34 AM Author Share Posted 29/05/12 07:34 AM On 29/05/2012 at 7:27 AM, turbowelshy89 said: Interested to see how the blended oil behaves. Maybe a silly question but if you blend 30 and 50 won't that just give you a 40 or is there something I'm missing. Unless you can't get the desired brand/make of oil in the desired weight?Sent from my HTC Velocity 4G using Tapatalk 2Only if you blend 50/50 which I have not Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1245137 Share on other sites More sharing options...
turbowelshy89 Member 147 Member For: 14y 9m 13d Posted 31/05/12 04:31 AM Share Posted 31/05/12 04:31 AM Ahh touche, what blend are you going for, or is it more trial and error based on how the engine behaves, noise, oil psi etc?Sent from my HTC Velocity 4G using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1246335 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 4m 15d Gender: Male Location: Perth, WA Posted 31/05/12 08:54 AM Author Share Posted 31/05/12 08:54 AM On 31/05/2012 at 4:31 AM, turbowelshy89 said: Ahh touche, what blend are you going for, or is it more trial and error based on how the engine behaves, noise, oil psi etc?Sent from my HTC Velocity 4G using Tapatalk 2Trial at the moment, just to see what is best to keep engine happy, but looks like it may end up at a 40 viscosity. Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1246574 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 2m 3d Gender: Male Location: Gladstone, Queensland Posted 03/06/12 07:55 PM Share Posted 03/06/12 07:55 PM Ninka, curious to know by what parameters you are using to guage the effects of different viscosities in your new built motor. Although I will have to trial a few after I build my new one the stock engine in my ute now seems to like a 40 oil, my last oil change I went to a 50 and the motor seems less smooth and less responsive although its mostly a feel type thing its probably just all in my head but I will be definately go back to a 40 if I clock up enough ks to justjfy another oil change before the fresh engine Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1248789 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 4m 15d Gender: Male Location: Perth, WA Posted 04/06/12 03:30 AM Author Share Posted 04/06/12 03:30 AM On 03/06/2012 at 7:55 PM, 45T-XR said: Ninka, curious to know by what parameters you are using to guage the effects of different viscosities in your new built motor. Although I will have to trial a few after I build my new one the stock engine in my ute now seems to like a 40 oil, my last oil change I went to a 50 and the motor seems less smooth and less responsive although its mostly a feel type thing its probably just all in my head but I will be definately go back to a 40 if I clock up enough ks to justjfy another oil change before the fresh enginePurely sound of engine, as the quite short pistons I have used are very particular to oil viscosity, or they will rattle a little. I think like you, I will settle on a 40 as the best choice. Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1248958 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 2m 3d Gender: Male Location: Gladstone, Queensland Posted 05/06/12 03:44 AM Share Posted 05/06/12 03:44 AM Yeah ok, cheers for the feedback. Although I have chosen the same pistons as you, ive gone with the 698kw rods and kept the piston/bore clearance as per cosworth/atomic specs. Will see how it likes the 40 oil Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1249551 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 13d Gender: Male Location: Far north queensland Posted 05/06/12 05:09 AM Share Posted 05/06/12 05:09 AM be careful when blending oils, I know it's not as bad as blending greases but it would be worthwhill doing a viscosity test on your blend before you put it in and again when you do a change Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1249623 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 4m 15d Gender: Male Location: Perth, WA Posted 05/06/12 05:27 AM Author Share Posted 05/06/12 05:27 AM On 05/06/2012 at 5:09 AM, sexual harrassment panda said: be careful when blending oils, I know it's not as bad as blending greases but it would be worthwhill doing a viscosity test on your blend before you put it in and again when you do a changeI don't think this is a problem, as long as same brand and types of oils are used.This can be evidenced by the oil pressure of the engine as well, as it increases slightly and gradually the more higher viscosity is added to the mix. Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1249640 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 13d Gender: Male Location: Far north queensland Posted 05/06/12 05:46 AM Share Posted 05/06/12 05:46 AM yep same brands and bases it should be sweet Link to comment https://www.fordxr6turbo.com/forum/topic/77388-my-new-engine-build/page/9/#findComment-1249652 Share on other sites More sharing options...
