Ninka Donating Members 1,850 Member For: 21y 11m 5d Gender: Male Location: Perth, WA Posted 16/10/11 03:00 PM Share Posted 16/10/11 03:00 PM Well it's been a while since I posted anything substantial, so for those of you who know me, and have followed my past technical adventures, you will know I'm a bit of a nutter for mechanical finesse, and in the quest for a VERY strong engine, with a stock level of mechanical 'noise' I.e. no rattely noises at all, I am just in the process of completing my latest engine project for my '02 BA XR6T (the one with the ZF 6 speed).I thought I would share what I have been doing, for those of you interested in the technical aspects of the engine building process.New engine is built with the following modifications over stock BA:Head machined and vacuum checkedBF CamsTitanium Valve Spring RetainersHarder Valve SpringsStainless single groove race Exhaust ValvesHeavy Duty Cam ChainHardened Cam Chain GearsHeavy Duty Chain TensionerModified Oil Pump with Billet Gears and larger passagesEngine Block checked for wall thickness and tunnel straightness, machined and bored to proprietary tolerancesCrank checked and oil passages radiusedCosworth Forged PistonsHeavy Duty Billet Con Rods (998kw rated)Race BearingsHeavy Main Bearing BraceCrome Moly Heavy Duty Flexplate and ARP boltsI am building engine myself, but all performance parts have been supplied by Atomic, so thanks to Brad for his help with getting this together.I hope to get the time over the next few weeks to change the engine over with my current unit, which last we dynoed it, ran 363 rwkw, and hasn't missed a beat, but the Mahle pistons are not 100% quiet at the tolerances I used for that engine, so here's hoping the next one does the trick...... 2 Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 9m 21d Gender: Male Location: SW Sydney Posted 17/10/11 02:38 AM Share Posted 17/10/11 02:38 AM All those that want to learn something, watch this thread...Good to see you posting again Ninka Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 3m 9d Gender: Male Location: Zombie Birdhouse Posted 17/10/11 02:57 AM Share Posted 17/10/11 02:57 AM Good onya Alan , the beast is getting beastier.If the ZF conversion thread is anything to go by , watch this thread as P@@ says Link to comment Share on other sites More sharing options...
MurdoK Donating Members 719 Member For: 14y 5m 7d Gender: Male Location: Perth,WA Posted 17/10/11 05:06 AM Share Posted 17/10/11 05:06 AM Hey Alan I'd wish you luck, but after after speaking to you a few times and seeing your car at a few cruises I dont think you'll need it.Cant wait to see the new incarnation of your BA Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 11m 5d Gender: Male Location: Perth, WA Posted 17/10/11 10:30 AM Author Share Posted 17/10/11 10:30 AM (edited) Thanks Guys :sungum:The process started by stripping back a good BA N/A head I had from an engine I bought some years ago, I then had gasket surface and seats machined, and all valves vacuum checked with the new single groove exhaust valves.The bare N/A head is identical to the Turbo heads, except that the exhaust valves are different (higher heat tolerance), so these needed to be replaced. I looked at the option of replacing with Ford standard Turbo valves, but ended up choosing a proprietary swirl polished single groove valve, as the single groove design 'clamps' the valve stem, stopping the valve rotating quite as much as the looser multi-groove units used stock. This helps a little with noise, but importantly, at higher revs, reduces valve wear, as the exhaust valve is moving more or less straight up and down, with virtually no rotation when it meets the seat.Following the preparation, I checked the valve guides and other components, fitted new valve stem seals, Atomic valve springs, hydraulic lifters and rocker arms - Head done..... Edited 17/10/11 10:30 AM by Ninka 1 Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 11m 5d Gender: Male Location: Perth, WA Posted 17/10/11 10:50 AM Author Share Posted 17/10/11 10:50 AM Oh, I forgot, I also fitted Atomic Titanium valve spring retainers, just to keep the weight of moving parts down a bit Can be seen in pic DSC_1620.Also finally got my picture library cleaned out, so a few pics attached. Link to comment Share on other sites More sharing options...
Shyfrd Turboless Donating Members 5,992 Member For: 13y 9m 1d Gender: Male Location: Geelong, Victoria Posted 17/10/11 10:58 AM Share Posted 17/10/11 10:58 AM topic: watched.I look forward to this build progress and how it turns out. good luck with it all, cant wait to see it all together! Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 6m 3d Gender: Male Location: Melbourne Posted 17/10/11 11:06 AM Share Posted 17/10/11 11:06 AM Talk about breathing life into the old girl, definitely keeping an eye on this. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 5d Gender: Male Location: Perth Posted 17/10/11 12:25 PM Share Posted 17/10/11 12:25 PM having seen the engine first hand i can say,perfection as always,wouldnt expect any less Allanhow much poost are you going too run through this one......... Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 11m 5d Gender: Male Location: Perth, WA Posted 17/10/11 01:53 PM Author Share Posted 17/10/11 01:53 PM Not sure on the poost Luke, all depends........Oil pump was modified, with billet gears, and re-working of oil relief passages, to allow the pump to bleed oil more quickly on overpressure, preventing pressure spikes on high rpm, and with that, hopefully avoiding valve lift, and other unintentional consequences. Oil pump was then ready to be fitted.Well next step was the fitting up of the block, pistons and crank.There I first started by carefully measuring each bore, and recording the size against the tiny differences between each of the pistons, so I got an optimised, and as near to 100% equal tolerance across all 6 cylinders, which I was very happy to have achieved, as near as I think possible. Piston ring gaps were then made to the tolerances I have used on my current engine, and again taking great care that they were all equal.Crankshaft was then checked, and oil passages radiused to clear the nasty sharp edges which are there from factory, after which everything was cleaned carefully, and assembly could begin.First the crankshaft was fitted and checked for thrust clearance, then the 6 pistons were pushed into the cylinders, and small end bearings fitted, paying particular attention to the custom drilled oil passage in one of the shells (as supplied by Atomic) to allow the pressurised oil feed to the gudgeon through the centre of the conrod. This was followed by careful torquing of the ARP bolts on the small end bearing caps, ensuring proper lubrication using moly grease supplied with the bolts.After finishing all the little ends, the main cap bolts have to be removed again, to allow the heavier Atomic girdle to be fitted (cannot be done earlier, as bolts for con rods would then be inaccessible, and unable to be torqued) girdle was then fitted, and main cap bolts greased, and torqued to specified torque.Oil pump was then fitted.After this it was just a matter of bolting it all together, and fitting the hardened cam drive gear on the crank, heavy duty cam chain and tensioner, and then throwing on all the covers and sump, which all went pretty well without incident. Prior to fitting, I 'prettied up' the front cover, with a high gloss silver aluminium paint, and re-painted the valve cover in the nice 'T' RED.A few more photos on the assembly of block/pistons attached. Link to comment Share on other sites More sharing options...
