Any Brake Upgrade To Fit Under My Standard 17 Bf Rims
  • Member For: 14y 5m 5d
If all that matters is performance why upgrade the brakes at all??
Get some decent rims and proper brakes, you'll need wider rims for decent rubber anyway if you want 500rwkw and to take it to the track.
Everything's a compromise really, if you want it to stop properly (which obviously you do) you might have to make some sacrifices.
  • Member For: 15y 1m 26d
You are right I just hope they fit cause I don't want any extra attention as this will be driven daily on a daily tune so I wanted sleeper look! Maybe I can compromise to have brake/wheel setup for track as they don't come around that often and would only take couple of hours to change over! Can any1 tell me definitely that ba xr8 18" will fit over brembos 6 and 4 spot?
  • Awesome...
  • Member For: 14y 11m 10d
The offset is the main problem when fitting bigger brakes. The 18's are the only factory FORD wheel that will clear brembos - I believe all FPV wheels will clear however.
  • Member For: 16y 10m 30d
If you want to go with the sleeper look, just paint the whole lot flat black, then people won't notice any of it. Personally, I rather like the obvious look. This is on my taxi.
But, if you want subtle then paint it all black and people won't be able to see it, especially at night.
Besides, I don't think that police are going to hassle you for having a set of Brembo brakes. If anything, a roadside chat might go your way once you explain that you focused in performance brakes and suspension before pursuing more engine performance. Keep in mind that cops are used to turning up at car crashes where the driver has stuffed up and exceeded the ability of the car (ie weak brakes, crap suspension).
Edited by PhilMeUp
If you don't want to go with a Brembo setup, then try and find some calipers from the BA Premium Brake Option. They are extremely hard to find, but turn up on eBay and forums occasionally. These are generally regarded as the best option below a Brembo setup. They use a 325mm disc, but the disc is 32mm thick instead of the usual 28mm.
I put a set on my girlfriend's taxi yesterday afternoon, with some secondhand DBA4000 disc rotors. There is a noticeable difference over the standard 298mm stuff.
  • Member For: 22y 2d
I've been away awhile
So maybe I don't understand
But considering the price of a good brake setup... and the fact it will one day save you life, that of your family , and other road users
Not to mention the front of your car not ploughed into the back of the VT Late model camira full of bogans ahead of you
And relative to the cost of your 'performance' upgrades that seem more important to you ... just do it man
I'm not particularly a fan of the 6 pot Brembo... I think they are abit big and the pads too agressive on the poor quality factory discs... but a nice 4 pot should do the trick
Either the Brembo... or call V-Sport and get the AP Club Spec version in 330mm with a matching 315mm rear
http://www.vsport.com.au/ecommerce/index.php?categoryID=145
More than adequate for what your planning
I'll go get back in my box now
