  • Pitlane Member
  • Member For: 17y 11m 10d
Hi Mike, I am not sure, maybe 100kg's? The system is designed to start up on petrol and then switch over to gas, this is to avoid the issues associated with starting on gas. I think with this system you need to keep the petrol system. I am not sure how much petrol you need to keep on hand, I haven't got that far yet. Again, Mick will be able to give definite answers!
  • Member For: 18y 10m 15d
  On 07/12/2011 at 11:47 AM, fordfreak1 said:
ooohh exciting stuff
so mick your saying if we go just stock, then want more power later on, we can get that extra pump added? but its a pita I understand?
so you just have to remove the multivalve, add 2nd pump and then all sweet for more power?
The kits come set up for standard cars
Yes the pump can be added at a later stage but is more expensive to do it this way
We do a few mods to the systems ourselves to help things work
  On 07/12/2011 at 12:11 PM, Shyfrd said:
ute would make it so much easier to add pump later on I assume. especially if lid is off..discounts mick for tuning half a car? hahahah
Either body style requires the tank to be emptied and then removed
I was going to say we might give discounts for half a tune, but we don't do half a$sed jobs :mosking:
  On 07/12/2011 at 9:19 PM, MiKa said:
How much weight would the tank add? Are there gas only setups? No petrol..
The system requires approx a 55 second purge time, at this point is is illegal to have gas flowing for that period of time, so the car needs to remain a dual fuel setup which starts on petrol and continues to run while the lpg purge is happening
  • Member For: 18y 7m 22d
Mick to the rescue hehehe...
Sounds good.. Is this the same sorta thing Worm has/had? Is say 270rwkw on gas different to 270rwkw on Petrol in terms of power delivery, timing, boost etc??
Its a decent outlay but in the long term I should pay itself off?
Good luck Daniel hope you get some good results..
  • Pitlane Member
Thanks Mike,
The car is definitely in the right hands to get what I am after! I do a lot of km's so expect to pay of the gas system (not the tune, cat, etc) in 12-18 months.
As for everything else you asked.....Mick? :idunno:
Edited by TRA1NR
  • I <3 Floods
  • Member For: 13y 8m 11d
Geez.. Stop asking Mick questions and let him finish the damn car so we can see the results..
  • Pitlane Member
Nah brenno mick just answers questions in his breaks! Will be a few days wait yet!
Edited by TRA1NR
  • I <3 Floods
Could be a couple days if he stopped taking breaks :stirthepot:
