  • FREAKY
  • Member For: 15y 6m 2d
ahh I see. makes sense now.
lol toroidal tank are funny things, but arnt they smaller than the standard boot tanks?
surely there has to be a better way if you want more power down the track, other than cutting open the tank to put another pump in there surely?
Edited by fordfreak1
  • Pitlane Member
  • Member For: 18y 1m 26d
The toroidal tanks are lower capacity, I am not sure how much though.
I am not sure on the possibility of external pumps, I am guess ratter would be the best to answer.
  • Pitlane Member
Thanks mark, still hanging out for it! Not long now though!
  • Member For: 19y 1m
Your car is now running on LPG
The set up does not allow 2 tanks to be used. The tank does n ot need to be cut open to do the pump, there is a multivalve which can be removed to modify the tank and fit the 2nd pump. It is cheaper to do it when the kit is being assembled and before the tank is fitted and filled.
  • Pitlane Member
Cool, thanks for clearing that up mick! What is the timeline for pickup? Or are we waiting on the weather to turn sh*t?
Edited by TRA1NR
The car is sitting on the dyno and now I have to start the tuning and then making adjustments to the gas system as required etc so there is still some time in what we have to do, but the main problem is the tank looks like it may have to come back out again as the fuel gauge is not working, will need to do this after the tuning as we have to burn off any gas that is in the tank before opening it up, so figured use the gas in there now to tune and then get the gauge looked at
  • FREAKY
ooohh exciting stuff
so mick your saying if we go just stock, then want more power later on, we can get that extra pump added? but its a pita I understand?
so you just have to remove the multivalve, add 2nd pump and then all sweet for more power?
  • Turboless
  • Member For: 14y 4m
ute would make it so much easier to add pump later on I assume. especially if lid is off..discounts mick for tuning half a car? hahahah
