Fg Xr6T Faulty Bluetooth Or Not Installed?
scottwallbank
  • Member For: 13y 2m 12d
I have just purchased a 2008 FG XR6T and can't work out if the bluetooth function is not working or just hasn't been installed. The ICC menu has a phone option that I can not acces which I originally thought meant that the module has not been installed but I noticed a bluetooth symbol on the ICC screen just above the antenna icon and also the phone button is on the steering wheel.
Any help would be appreciated.
  • Member For: 14y 10m 29d
if you press the phone button, or hold it even does it do anything on the screen.
If you read your manual there should be a way of putting the system into pairing mode so you can set it up on your phone to connect.
  • Member For: 13y 5m 9d
I'd say there is something wrong if it doesn't let you access the phone section in the menu.
Sent from my HTC Desire using Tapatalk
  • Sucker
  • Moderating Team
  • Member For: 20y 7m 22d
Try pulling the applicable fuse, cycle your ignition and then replace the fuse and see how you go. Can't recall the fuse number so you'll have to check your manual...15 maybe :dontknow:
Mine did that occasionally,they ended up replacing the module under warranty.
