johno Donating Members 773 Member For: 14y 7m 4d Gender: Male Location: Mt Gambier, SA Posted 12/10/11 10:00 AM Share Posted 12/10/11 10:00 AM earle, mine has an APS stage 2 kit. 3.5" exhaust, external fuel pump, cold air intake, larger injectors(dont know what size)GT valve springs, larger intercooler( I think it is a PWR), Plazmaman pipe kit, turbosmart blow off valve, and now a SCT flash tune.It has the turbo flapper/ported mod done as well. I am happy with the way it goes.My tuner said I have a waste gate actuator problem as well, which is limiting my boost. Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148630 Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 22d Gender: Male Location: Victoria Posted 12/10/11 11:09 AM Share Posted 12/10/11 11:09 AM It has the turbo/flapper modded but a stock actuator? WTF?Mine had 285rwkw with 10psi, typhoon intercooler, center muffler removed and k&n filter... On LPG... Put in a process west stage 2 cooler and piping retaining stock crossover for reliability and then did valve springs, once again for reliability... Same boost... Little bit more power...Stock cat, stock auto, stock intake, stock turbo and actuator... Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148706 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 3m 27d Gender: Male Location: Auckland, New Zealand Posted 13/10/11 04:18 AM Share Posted 13/10/11 04:18 AM I have my standard actuator with ported standard flapper. I stuck it back in when I replaced the motor because I was a bit nervous I was thinking of getting a 3.5" exhaust system with a 5" cat and a 4" dump and putting the 12lb actuator back in. The standard one seems to get on power ok if you keep your foot in it but if you button off a little and then go back on it doesn't seem to boost so well. I think I will be around the 320wkw fairly safely at modest boost if I do that. Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148858 Share on other sites More sharing options...
earle13 Member 58 Member For: 13y 11m 5d Posted 13/10/11 05:26 AM Author Share Posted 13/10/11 05:26 AM Why did you have to replace the engine riptide? Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148880 Share on other sites More sharing options...
Slash Donkey Dick Member 801 Member For: 15y 1m 26d Gender: Male Posted 13/10/11 06:42 AM Share Posted 13/10/11 06:42 AM On 12/10/2011 at 7:35 AM, BPRacing said: High Intake temps as a result of the continuouse dyno runs will contribute to a lower dyno figure in the final result.Run it up cold may allow the car to produce additional 10rwkwWhat? Higher intake temp than ambient temp results in the dyno working it's magic & guesstimating what the actual figure should be based on intake/ambient temps being equal. Making the sensor hotter will increase power figures by cheating, putting a decent cooler in to control intake temps will also show a marginal increase, but will keep it repeatable.All this bitching about what your car made in comparison to this one & what it should have made is rubbish. How many times does it need to be said that dyno's are a tuning tool, nothing more? Unless you're on the same dyno on the same day placing the sensors in exactly the same location & strapping down exactly the same way, comparisons should never be made.Everyone putting their 2c in about their power figures, post up your mph as well for a fair comparison please. I bet they will all be fairly similar based on a car with same transmission & mods to the OP's car. Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148898 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 23d Gender: Male Posted 13/10/11 06:48 AM Share Posted 13/10/11 06:48 AM (edited) and well said Slash. Even though you think your GTR can beat my bike. Edited 13/10/11 06:51 AM by pazzo xr6t Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148901 Share on other sites More sharing options...
Slash Donkey Dick Member 801 Member For: 15y 1m 26d Gender: Male Posted 13/10/11 06:59 AM Share Posted 13/10/11 06:59 AM Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148904 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 3m 27d Gender: Male Location: Auckland, New Zealand Posted 13/10/11 08:34 AM Share Posted 13/10/11 08:34 AM I had some engine trouble earle http://www.fordxr6turbo.com/forum/topic/74009-just-blew-my-engine/page__fromsearch__1 Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148949 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 1m 25d Gender: Male Location: Vic Posted 13/10/11 09:02 AM Share Posted 13/10/11 09:02 AM I wanna see a thread on this gtr. Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1148968 Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 8m 24d Gender: Male Location: Melbourne, VIC Posted 13/10/11 12:17 PM Share Posted 13/10/11 12:17 PM With stupid.. Link to comment https://www.fordxr6turbo.com/forum/topic/77303-got-the-ba-custom-tuned-heres-the-dyno-sheet/page/4/#findComment-1149032 Share on other sites More sharing options...
