  • Member For: 18y 4m
My Bogan chariot - have had it a while but just got around to it...
Plazmaman Plenum, 1800hp Cooler
80lb injectors
valve springs
turbo flap mod
Process west battery, cold air and fuel surge kit
Cam upgrade
Side exit-exhaust
1800hp Clutch
6sp Mal Wood Box
Runs 321rwkw, just over 800NM Torque, spikes boost to 22PSI.
post-10334-0-66482200-1318257450_thumb.j
post-10334-0-04525700-1318258424_thumb.j
https://www.fordxr6turbo.com/forum/topic/77291-ba-xr6t-utility-321-rwkw/
  • Member For: 15y 5m 17d
strange that it spikes to 22 and is tuned to 16psi?
What dump/cat do you have? The mods listed should be good for 360 ish. But tuned at elite is a good thing :)
  • Member For: 17y 23d
Those 1800hp coolers are farkin massive!!!
Power figure seems low though, with those mods you'ld expect 320@ closer to 13psi, 22psi should be 420.
Got anymore pics of this beast?
  • Awesome...
  • Member For: 14y 9m 7d
Looking at the dyno chart it is running 16psi tapering down to 14. If its spiking to 22psi since you have had the tune done either your boost gauge is rubbish or something is amiss, I would be taking it back to the mechanic.
True, thanks for the advice - I'm not sure - its an Eboost 2 gauge and I can check it to tell me the Peak hold boost when I've been driving, and I'm pretty sure its only in 2nd gear.
Its running a little lower power than it could, as I haven't put in rods and pistons yet, and anything over 320rwkw is playing with fire. She sounds pretty good idling, with the cam lumpy enough to make the entire thing shake side to side. I'll upload some pics/sound soon if possible.
