Are Mickey Thompson Et Streets Legal In Nsw ?
thesal
  • Member For: 13y 9m 27d
thank for the advice guys, did some research..
1/ I called Rocket and they said the MTs are NOT street legal inSW
2/ I called the RTA and the "techniciain" said they are fine as long as there is sufficient tread depth and they are the appropriate tyre for the rim (go figure??)
3/ I like the sound of the NT05's. Read some reviews and they get a good rap.
4/ thanks sideways82 and Tobey..spoke to Mick at Taleb and he will do the NT05's at $250 a corner (in 245 40 18)
gonna sleep on it and do a little more checking tomorrow.
  • G666E Turbo!!!
  • Member For: 15y 2m 22d
Don't get the NT05, they just skate down the road, if you want to corner hard then yes get them, if you want to get nitto's get the invo's
I have a little more power than yours, 311rwkw on a real dyno so about 350rwkw on the tunehouse thing LOL with nt05's as soon as the car has moved 1 length from a stand still it will fry the tyres then hit 2nd and fry them lots more, even after I did a few km and scrubbed them in and even when warm, try a real semi if that what you really want.
Like I said on $$160 acceleras in the same car that ran 11.6 I get a tiny bit of wheelspin top of first and if I'm lucky and tyres are cold a little into 2nd. After driving 20min no 2nd gear wheelspin at all unless I launch in 2nd hard off the line under boost and even then it's just pretty gay, so I was thinking man my car is broken, so I put on new 22" nexen rubber and hello 2nd gear smokes them again :)
The rta guy is wrong, the ET's aren't speed or load rated and NOT legal in Aus, the NT05R are loadnubt not speed rated again NOT legal, something like an R888 is legal but $$$
Bit seriously on a good bit of road with under 300rwkw you won't get rid of 1st gear wheelspin but you can get a massive improvement. That said I'd still like to try the et's in the 245/40/18 I believe they are also the ET street 2pattern so the look liker a normalish tyre
Edited by MexicanBatman
  • Waiting for the 1st N/A 12!
  • Member For: 17y 1m 28d
M bat your boost must come on sledge hammer style if your frying Nt05's in 2nd with 311 rwkws.
I've now had both the Invo and the Nt05 on the back of my FG (well over 400 rwkws) and the Nt05 imo does grip a little better than the Invo but yes as you mentioned certainly out corners the Invo!
Thesal mate I'd recomend you wait for the new batch of invo's and opt for a 255/40/18 that will sort you out!
quite a contrast of info here now...
Mexican B, dynos aside, I too get massive wheel spin when boost kicks in even starting in 2nd (it's an Auto) and that's after a burnout or two and 30psi in the OEMs...what's wrong ith these damn dunlops??
Never heard of the "Accelara". Who makes them and does ayone else recommend them ?
hmm a 255 eh?...could be the perfect solution if these invos are nice and soft!
invo's are tread wear 260 apposed to the NT05 at 200!
But mate nothing but good things to say about the invos (I still run them up front) I was even able to out 60ft some guys at WSID recently on MT's with several 1.8's!
M Bat what NM's is your girl making?
  • G666E Turbo!!!
sorry dude about that dyno thing I was being a dickhole LOL
the accelera are a cheap crappy indonesian tyre
and my car is tuned so boost comes on quickly but its smooth as and I dont even notice it now and runs a sh*t load less boost than other FG's ive seen (some running 21psi!!!) peaks @ 15psi tapers off and makes max power on 12psi my daily tune makes 7000N @ 120km/h and 303rwkw the other tune I run makes 6900N @ 132km/h and 311rwkw both tunes did an 11.7
in terms on NM I have no idea, she needs lots more power, but im kinda bored and over it now, so im going to retune it a few things I want altered and ZF tuned and just drive it...
  • Member For: 15y 5m 13d
I have also seen the accelera do well down the strip. I had federal rsr and the bloke beside me had the cheapos, both bf's woth the zf, he had a bit more power but was getting more grip then me. Only 1 to 2 mph difference between us across the line but he was .3 sec quicker overal and .1 quicker at the 60ft mark.
but I'll still be going the invo fronts and nt05 rears, I like to corner.
