  • Member For: 13y 11m 26d
nizpro injectors , f6 intercooler and exh sys... 3 1/2 inch advanced dump to 3 1/2 ich to twin 2 1/2 threw front muffler to 3 inch rear muffler to twin 2 1/2 tips with tune as a starter . all parts are 2nd hand 4 bout 700ish . do u think would get a safe 300rwk with tune . then will concentrate on saving 4 a big cooler set up etc for another tune . or will I need a upgraded fuel pump b4
  • A much better forum
  • Member For: 16y 10m 26d
I would do the fuel pump with first tune... Good safety measure...
If you want 350 reliable kilowatts...
Valve springs may be ok (have to wait and see)
Exhaust you have is fine
60cc injectors
Process west cooler kits you have chosen will do it easy
You will need a 12psi actuator and to port your wastegate and put in a larger flapper to control boost (no one has mentioned this?)
You won't need a clutch as it's auto and auto will hold 350 fine
I'd suggest a surge tank... Look for a second hand one etc but definitely put one in. Good insurance
  • Member For: 14y 5m 8d
for a reliable everyday 350rwkw you'd be wanting to start looking at a built auto and bottom end (oil pump gears more importantly)
Seems a few people have had failures before hitting 350rwkw, but who knows how they drive...
  • Member For: 18y 23d
I don't think 350 in a standard ZF is worry free motoring, yeah they can handle it but that's well over there rating isn't it?
Also Worm 60cc injectors might be a tad small mate..
  • Member For: 17y 2m 29d
The motor should be fine, as long as it's been serviced, warmed up etc. Ba and reliable 350 is a different story I guess.
With dillz, a few have gone at 330s, I guess it depends on the tune, how you drive etc.
Air enough...
Guess it depends on tuner...
whistler6 has been running 380rwkw for over a year on a stock auto with no probs...
Don't forget kv's went wormy. He was running OWNEDU though haha
  • Member For: 14y 10m 22d
nah his was auto! he got it rebuilt, just back to standard though not strengthened
  • Member For: 14y 5m 30d
From memory, the ZF is rated for 650 Nm. Pity Ford didn't want to spend the money and put the better version in which is rated for 1000 Nm
Edited by PookeyMaster
