Photography Advice & Discussion Thread
Shyfrd
  • Pitlane Member
  • Member For: 17y 9m 16d
I have been using the light meter in the viewfinder, have not used the histogram yet, will have to look up how to use it!
Edit: Just been playing with the camera with the histogram turned on, thanks Adam! It adds another lot of information to take in and help me take a good pic!
Edited by TRA1NR
  • Here since the start...
  • Member For: 21y 9m 23d
I don't actually use the histogram myself unless I'm bracketing shots.
So when you're using the meter in the view finder do you just adjust the shutter speed and aperture to give you a 0 value. So properly exposed (according to the camera).
  • Member For: 17y 8m 23d
Talk is cheap fella's, lets get a day shoot going and you can all play with your cameras together?
Ok. So in doing that you're making the exact same decision regarding exposure the camera would've made for you in an instant. I'll try and explain it a bit better...
You're on Av mode f/8, ISO 100. You frame that shot and focus. In that instant the camera has decided the shutter speed needed to make that photo with 0 EV, so meter at 0.
Do the same in manual and zero the meter and the photo will be exposed identically. The only difference is it took longer to arrive at that result.
Shooting on manual doesn't add an extra element to the photo that is missing from the other modes.
  • Pitlane Member
ok, so to take advantage of manual mode, or get different effects to auto mode, I need to be shooting either side of EV 0?
If you want to under/over expose the photo, yes.
There's times when you might not agree with the cameras 'correct' exposure. That's when you can override that with exposure compensation. You're basically telling the camera to take what it thinks is the correct exposure and add or subtract whatever compensation amount you've dialled in.
This would be much easy to explain in practice. Maybe Dillz (finally) has a good idea?
  • Pitlane Member
Ok. If you are keen to run a daytime or nighttime photoshoot/workshop I would be very interest Adam!
As an example: If I want to shoot 3 images to make 1 HDR image, and want to over an under expose more than 2 stops then manual mode is where I would 'force' the settings I need?
Edited by TRA1NR
