  • Member For: 17y 2m 20d
damn that sucks, I really wanted to have a decent day out but sounds like its all gonna go to sh*t now. bruce has the car now for a retune for the cooler, wastegate and cat.. wont leave me enough time for a loop + harness
  • Banned
  • Banned
  • Member For: 12y 10m 7d
Harness took 1hour to fit and the loop was maybe an hour also.Get Bruce to fit a loop,hours labour on top of $40 loop itself,can help with dimensions if needed.Harness fits in back seat bolt holes...easy as piss:)
  • Banned
  • Banned
Will be up tomorrow by end of day,just got back from Watermark and stuffed.I took progressive pics so will be helpfull.
As much of a PIA it may sound it took less than a day to source pats and fit.
  • Banned
  • Banned
Here you go fellas.
Slightly modified universal loop bracket
Pic of straps heading to parcel shelf for bolting down
Pic of mount for waist strap with main buckle,its mounted on rear left seat bolt,I may weld this to seat bracket also but undecided.
Pic of mount for other side waist strap going to factory belt bolt hole.
How it looks all sitting as per going to buckle yaself in:)
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 27d
Whats the bollocks with nothing past 45degrees though ? Wouldnt that make the rear straps in the rear seat or lower rear foot well area?
  • Banned
  • Banned
Its 45* from your top of shoulder,the anchor points I was going to use(back seat belt holes) is borderline for me even with seat all the way down.Anymore than 45* and in an accident the strap will compress your collarbone/neck causing drastic injury or more.
