  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 17d
sounds like fuel filter is clogged have u chaged it recently?
  • Member For: 14y 7m 27d
haven't posted on here in a while. my cars at the panel shop being repaired. I hit a koala , demolished bar, got assessed then hit a roo on the same spot and took out guard. two claims later (6000) I'll have her back ready to install diff. least this time wasn't as bad as the first time it went in ... that claim was over 8k. got a 3.46 to go behind the zf untill I put the manual in. still need to get a fuel line made up to run the surge tank and twin 044's. anyone know if the stock fuel reg will handle the two pumps?
  • GONE FULL WIZARD
  • Member For: 16y 4m 12d
You'll love the 3.46 gears behind the ZF, I do after having it done :) If going a manual wouldn't you want 3.73 in there as a minimum?
  • Member For: 14y 6m 14d
The stock reg is fine for a single 044 but pretty sure u will need an aftermarket reg for the twin set up
