JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 24d Gender: Male Location: Adelaide Posted 25/02/12 02:20 AM Share Posted 25/02/12 02:20 AM iam a hearing ya foon gobble gobble and heat dont work so well the next day 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1201398 Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 16y 2m 1d Gender: Male Location: Adelaide Posted 25/02/12 09:00 AM Share Posted 25/02/12 09:00 AM On 24/02/2012 at 11:55 AM, BF6 said: Looks like a big tank for 1.6 litres. What width and length,height?Its no that big when you look at it in person..The mounting plate is what makes it look big. Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1201587 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 24d Gender: Male Location: Adelaide Posted 25/02/12 10:05 AM Share Posted 25/02/12 10:05 AM does it have a baffle in it wayne? a surge tank is supposed to reduce/eliminate swirl aswell Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1201632 Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 16y 2m 1d Gender: Male Location: Adelaide Posted 25/02/12 10:22 AM Share Posted 25/02/12 10:22 AM (edited) Mate not sure...Looking in the bottom 1/2 fitting it looks like there is some sort of plate inside or baffle inside...hard to tell though through the small hole...Is there a need for a baffle??? As the the pressure pump is drawing from the bottom of the swirl pot. so doesnt matter which way you turn or accellerate there will always be fuel.. ?The idea behind it is to supply it with fuel all the time, via a low pressure fuel pump. If it's always full there's no need for baffles, as there should be no sloshing back and forth in a full header tank. Edited 25/02/12 10:27 AM by KWIK F6 Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1201640 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 24d Gender: Male Location: Adelaide Posted 25/02/12 10:27 AM Share Posted 25/02/12 10:27 AM (edited) yeh but its the swirl on low tank that causes havock with a normal system hence the swirl/surge tank gets added in to reduce /eliminate the effect if its just like 2 fuel tanks the possiability for surge/swirl can still happenplates in the tank is a good sign its like water going down the bath plug hole looks like a twister need to interupt that effect Edited 25/02/12 10:28 AM by JETSNOT Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1201644 Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 16y 2m 1d Gender: Male Location: Adelaide Posted 25/02/12 11:08 AM Share Posted 25/02/12 11:08 AM yeah fair call...so as long as you have at least half a tank of motion lotion in the back swirl shouldnt happen? More of a problem if your trying to do a run with minimial fuel to reduce weight? Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1201661 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 24d Gender: Male Location: Adelaide Posted 26/02/12 01:39 AM Share Posted 26/02/12 01:39 AM yes but with correct baffles in place u should beable to do a run with less than a 1/8th of a tank safely (400mtrs) Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1201793 Share on other sites More sharing options...
A300srt8 Member 507 Member For: 20y 4m 29d Posted 26/02/12 10:32 AM Share Posted 26/02/12 10:32 AM (edited) Clipsal 500 ticketsI have 2 4 Day pit stright tickets section E seats 1 & 2 row G these are on the end of a row with no one in front ,just a 5 foot wide walk way,Perfect not all cramped up in front with people pushing thruselling for list cost 265 eachPM Details Edited 26/02/12 10:33 AM by BOSCO Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1201967 Share on other sites More sharing options...
09sr5 Member 56 Member For: 14y 8m 4d Posted 26/02/12 05:49 PM Share Posted 26/02/12 05:49 PM On 24/02/2012 at 7:20 PM, Foon said: Dude its in Queensland lol, doubt we would have seen it.Tell you what I have seen, see below -And before we found the above lolsame thing happened to my diff, part of the carrier and side gears fell onto the road. happened just yesterday. and as with other major failures on my car we have this one on video too Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1202085 Share on other sites More sharing options...
09sr5 Member 56 Member For: 14y 8m 4d Posted 26/02/12 05:53 PM Share Posted 26/02/12 05:53 PM On 25/02/2012 at 1:38 AM, JETSNOT said: hahah good times with those fukkrsavo so u must be running the avo cooler kit?, sounds bad that it split but the avo kit for b series is very underated in the modifying scene its a good kit that has had wicked resultspics of blow out? good for a laughnot sure tbh I presume it would be an avo cooler. more breaks = more fixes = more reliable Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/639/#findComment-1202086 Share on other sites More sharing options...
