  • Bob the Freaking Builder
  • Member For: 15y 8m 11d
  • Gender: Female
  • Member For: 16y 6m 26d
Anyone know if Bruce will install my gauges for me or anyone on here wanna help if I throw a carton their way. Drift Iridium Boost, A/F ratio & Oil Pressure.
  • Member For: 17y 2m 16d
what gauge pod do you have?
you will need a sandwich plate or tee for the oil pressure..
boost is easy!
I may be able to help, when were you looking at doing it?
  • Member For: 16y 7m 28d
they look sweet dude, I got the boost and a/f gauges in mine. dont be alarmed in summer when the screen is completely blued out due to the heat, soon as it cools down it goes back to normal
  • Member For: 16y 8m 26d
  On 23/09/2011 at 3:12 PM, SPOOLAX said:
Rapid V1 kit, 60lb Injectors, fuel pump, acuator, xforce 4" dump into 3.5" system mate
VL God Series Moonsteel Rods, VL God Series Plasma Plenum, Boeing 747 Fuel pump, ex USAF F15 dump pipe
It's really easy mate I'm putting a tripod gauge setup in mine you can come around and do you're own at the same time with my help if you like.
The oil pressure gauge will require the oil to be drained to fit the sandwich plate under the filter so just install the gauge and run the wires then you can have it hooked up with your next service.
