JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 28d Gender: Male Location: Adelaide Posted 05/07/11 09:10 AM Share Posted 05/07/11 09:10 AM seems to be a very popular problem with any zf that's had a tune wot in normal "d" and 1-2 change hit limiter mind u it comes on bloody fast that's why short shifting works but that just translates to wheel spinning mid to top of 1st then short shifting and spinning through 2nd Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120362 Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 16y 2m 5d Gender: Male Location: Adelaide Posted 05/07/11 10:54 AM Share Posted 05/07/11 10:54 AM On 05/07/2011 at 8:53 AM, Street Tuner said: I will set it up hard for 'Jetty' to drive then Will you be offering your zf chooning magic for some $$$ or do we have to wait for Brucey to get qualled? Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120394 Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 16y 2m 5d Gender: Male Location: Adelaide Posted 05/07/11 10:58 AM Share Posted 05/07/11 10:58 AM (edited) On 05/07/2011 at 8:53 AM, Street Tuner said: I will set it up hard for 'Jetty' to drive then :3gears: Edited 05/07/11 10:59 AM by wayne2106 Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120397 Share on other sites More sharing options...
A300srt8 Member 507 Member For: 20y 5m 3d Posted 05/07/11 11:21 AM Share Posted 05/07/11 11:21 AM On 05/07/2011 at 8:59 AM, JETSNOT said: one thing I know would be good to see is the zf shift b4 it hits limiter because it just cant keep up in std form that's why short shift 1-2 works so well but it would be nice to see it keep up your just slow on the gear change Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120407 Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 5m 5d Posted 06/07/11 05:25 AM Share Posted 06/07/11 05:25 AM (edited) To tune the ZF requires that you tune the engine as well - its part of one flash process, so unless you want your engine retuned (?) there is no point in coming to me for it, as your tuner already has your base engine tune file - unless they want to give you that to bring along for the ride....not that there is too much magic in most of it. For example an injector/cooler/exhaust/wastegate FG shouldnt be more than a couple of hours work from scratch. Edited 06/07/11 05:26 AM by Street Tuner Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120553 Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 5m 5d Posted 06/07/11 06:25 AM Share Posted 06/07/11 06:25 AM (edited) Note: I also tested full throttle upshift with my 310rwkw (Mainline) test car today (Herrod G6E) that I am doing transmission calibration on. It will shift before the limiter WOT 1/2 with both the stock and upgraded ZF programs. Not shifting before popping the limiter is indicative of wrong Torque settings in the engine program which enables the clutches to slip before the gear can be engaged in time. This should not happen, and isnt particularly good for the transmission - it is quite fixable Edited 06/07/11 06:26 AM by Street Tuner Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120563 Share on other sites More sharing options...
The Jizard GONE FULL WIZARD Donating Members 1,617 Member For: 16y 4m 23d Gender: Male Location: 720 East Kensington Road Posted 06/07/11 06:40 AM Share Posted 06/07/11 06:40 AM Mine was fine, just revved harder (over 6000rpm) on the auto shifts than what I like, only ever hit the limiter on brain fade manual shifts. Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120565 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 28d Gender: Male Location: Adelaide Posted 06/07/11 08:41 AM Share Posted 06/07/11 08:41 AM On 05/07/2011 at 11:21 AM, BOSCO said: your just slow on the gear changeI was reffering to automatic mode speed racer I can shift fine old boskie bear I shift so hard I blow out the sunroof with the speed incurred Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120608 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 28d Gender: Male Location: Adelaide Posted 07/07/11 11:12 AM Share Posted 07/07/11 11:12 AM blokes this is the write up I did for the zf tuning stuff by the looks of it every tuner in the country has the option to sit the course and get qualified so as soon as tuners pull there finger out it should hit the streets like a flood even k.p.m have there own threadon this k.p.mmy write upits a bit like everything blokes wait a little bit and the tunes will get better and better and the technology will be fine tuned aswell but a kick ass start to getting a hi stall in a 6 speed box what an ultimate package hey Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1120986 Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 16y 2m 5d Gender: Male Location: Adelaide Posted 07/07/11 02:12 PM Share Posted 07/07/11 02:12 PM Looks the goods ....Ill wait till Bruce has it sorted....If he says it works I know my trans is in good hands..His work speaks for it self Link to comment https://www.fordxr6turbo.com/forum/topic/77157-sa-members/page/405/#findComment-1121037 Share on other sites More sharing options...
