Sa Members
animalxr6t
  • Member For: 16y 7m 7d
he would of been there to hear if there was any knocking or pinning coming from the motor. ring around see wot shops will do an x force for if u get a better price just hit him up. emtech told me around 2,400 fitted when I was looking around but mite have gone up by now.
Ok thanks for the heads up, ill do some ringing first thing tomorrow morning.
Are morpowa open saturday mornings? I know alot of places wont be, I might have to stock up on numbers and ring them while im at work.
If I cant source out cheep injectors or springs, I might settle with exhaust and tune for now and once I get the rest ill get him to do the install, plus I should have a fair bit more spare cash to throw around if I wait a month so might do fuel pump and cooler with the second lot. But like I said before, well wait and see how the next week pans out.
Also, on an of topic note...
Spotted - black turbz on main north tonight, plates were "somthing somthing something xr6".
  • Member For: 19y 1m 21d
KPM Motorsport have been high flowing and blue printing injectors now for 9 years on all makes and models. We have been blue printing the Ford range injectors (Bosch EV6) since they were released, all with great results.
Our injectors are blueprinted to flow within 2% variation of each other and are fully tested for correct pattern, leak down and atomisation.
All injectors are then ultrasonically bathed and fully re-kitted before final testing and sale.
New injector variations are usually within 4% and we believe after our high flowing process, our 2% variation is more suited to the high performance engines which demand more exact fuelling. Prices listed below :
New Bosch 0 280 155 968 44lbs $98
KPM Blueprint 44lbs $70ea
KPM Blueprint 49lbs $70 ea
KPM Blueprint 54lbs $70 ea
KPM Blueprint 59lbs $70 ea
All KPM Blueprint injectors are on a change-over basis.
$40 extra per injector if no change-over is available.
Bosch EV6 injectors are the correct injectors for the Ford and Expensive Daewoo range of vehicles and give more precise fuelling due to the breakpoints being calibrated exactly by the factory computers. This means correct fuelling at all load points and rev ranges without the computer trying to fight the injector while in closed loop.
Customised tuning to these injectors becomes easier and less expensive due to precise tuning being achieved much quicker.
Larger EV6 injectors can be purchased on special order.
We also have a Full range of upgrade performace Valve springs in stock.
Edited by KPM Motorsport
Rang around, didnt get one single quote. No one had a price list readerly avalible on site so I have to wait till tomorrow or some time during the week for like 5+ places I rang. Chances are half wont ring back, but oh well.
YAY for the increase to 11g for the first home buyers grant.
Got a quote from Everlast Exhausts "8396 3255" for 2400 fitted. So that's the price im taking back to morpowa and hopefully they will do better than match it. So there it is, the cheapest quote I have gotten so far if any one was interested in a X Force full S/Steel 4" dump to 3.5" single pipe cat back exhaust with high flow x force cat. I would imagin the 2x 2.5" cat back wouldnt be much different in price.
But like I said, take that quote to morpowa and see that they will do for you. that's what ill be doing.
  • Cruise Control
  • Member For: 19y 7d
another option is to get one from here if you want to save 4 or 5 hundred
http://cgi.ebay.com.au/FALCON-BA-BF-XR6-TU...1QQcmdZViewItem
lots of people have bought from this seller and your local Mechanic/zorst place can fit it in a couple of hours or you could DIY
Edited by bloosted
1600 bucks is good. I doubt I would be able to fit this without a hoist though, I feel very capable of fitting an exhaust but for 300 bucks why not just get a pro to do it, then if it leaks I can crack the wobblies. Is this a genuine x force exhaust?
I dont want to buy it and it not fit, dont supose you know of a link to some one who has bought one and installed it? Just so I can see if they had any drama's?
I guess if its genuine I dont have to worry but I cant see the word genuine any were.
Thanks for the link.
