  • Member For: 17y 6m 7d
Hey after some advice....
So after spending the weekend at Murray Bridge skiing, I was driving back on the freeway (I wasnt towing). When it went from 110km/h to 100, I pushed down the the cruise control a couple of times. The trans shifted down a gear, with a bit of strange noise. Not long after I got a temp warning on the dash (flashing every few seconds, no beeps), the same icon as the coolant indicator. My autometer was reporting slightly over 100C engine oil temp (oil filter sandwich). I didnt think that was too bad, so I kept going.
Not long after the decent into Adelaide started, engine didnt have to work, and when the autometter gauge reported under 100C, around the same time the warning light disappeared. The trans didnt feel right to me though. After getting into adelaide, I turned down a side street to check under the bonnet, and picked a bad one. I tried to reverse and discovered reverse was gone :( Engine just revved. It when back in drive ok, but the BTR (4speed auto) adaptive and perf were basically the same, engine was always above 2000rpm. When taking off the trans let the engine rev a fair bit before going into second.
Further down cross roads I lost all power, and the car got really heavy. My arms really appreciated power steering disappearing after skiing. Battery light and oil light. Pulled over and the missus came and picked me up. Car started, but I figured I'd leave it for a bit. There was coolant in the reservoir, and oil on the dip stick. Battery isnt that old.
Came back and a mate followed me to the mechanic (Graham West is my tuner). Luckily he was there doing paperwork or something at 6pm on a sunday, so it locked it in the garage, will inspect tomorrow.
I'm assuming the trans is rooted. Which kinda sucks, it was only reconditioned 2 years ago, but at that time the car was stock, its now running 307rwkw. I've probably only done 10-15k km on it (car has only done 85k). Trans wasn't done by West to be clear.
Assuming the trans is f*cked, what are my options in Adelaide? I've got a BA MK2 with the 4speed auto. Is it possible to get the BF 6speed auto in there? Is that stronger? Who in adelaide can build a BTR up to strength for 300rwkw? At what cost?
Cheers
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 1m 4d
Arh ryan that's no good mate !
For the style of driving you do theres a few places and each of them will take around 3k off you for a drive in/out
M/V automatics lonsdale
SA race Expensive Daewoo hill
DRW at lonsdale as johno said
Dont get talked into a hi stall unless u became super passionate about drag racing overnight lol ;)
But make sure it does inc a new/rebuilt converter to stock stall specs or at least there alowing to cut/clean/weld your current one
Thanks for the advice guys (and girl). Plaza automatics were the ones that did the first one. Car was stock then, at the time I didnt know I was going to go for 300kw. They used AU planetaries as they thought they were stronger.
I'll stay away from the hi-stall, thanks Jet. Is it worth getting a shift kit?
Naturally the "built" or "strengthen" of an auto build automatically leads to tweaking the valve body inturn making it shift firmer then a tweak of the ecu after to suit the "built" trans will firm it up again
As long as they know what power u have infront of it everything should be smooth sailing
Yeh loosing reverse is not a great sign of it springing back into life
  • loitering with intent
  • Member For: 21y 10m 16d
Plugger most things don't just spring back into life , unfortunately for most of us
