  • You've changed man....
  • Member For: 14y 6m 3d
add us freeze...
btw this is staino... I f*cked with a mod and got owned..... for now ;)
Patch details
22 November 2011 - 04:08 AM Posted By Demizer 9
Notes for Battlefield 3 November 22 patch. Major client update for the PC version Battlefield 3 as well as a server-side update for all platforms. This Battlefield 3 update will be made effective on Nov. 22nd 7:00 AM UTC / Nov. 21st 11:00 PM PST.
We’ll share release timing on the console patches as soon as we are clear on the timing, these take a bit longer due to console certification process.
---- Client-Side Changes:
-- Visuals, Stability and Performance Fixes:
• General performance and loading time improvements
• “Black Screen” fix for an issue occurring on some PC Configurations
• Stereo and Rendering Support for Nvidia and AMD Graphics Cards
• Adjusted the “stuttering” encountered on some PC configurations.
• Fixed several Crashes when joining MP and Co-Op sessions
• Fixed multiple problems when using multiple monitors (Eyefinity / Surround).
• Fixed visual corruption issues on certain Nvidia Cards
• Improved loading times for certain textures
• Added console command “GameTime.MaxVariableFps” to limit max FPS
• Added console command “UI.DrawEnable” to hide UI for screenshots / videos
-- Balance and Gameplay Adjustments (PC)
• Fixed a problem with high speed mouse movement
• Added back some missing Growlers on Kharg Island Conquest Large
• Added back EOR sound for SQDM and TDM
• You should no longer be able to damage a friendly vehicle when sitting in an open position
• Grenades now drop to ground if you get killed while attempting to throw it(note the affect this will have on Hardcore mode!)
• Spawn protection now should work in Conquest. You should no longer spawn on points too close to enemies
• You should no longer spawn too close to enemies in TDM and SQDM
• Combat areas on Kharg Rush tweaked in order to disallow defenders to access the carrier ship after 1st base is taken and being able to enter the AA gun
• Fixed a problem with revived players not suffering suppression
• Fixed a problem with the camera when being revived in COOP
• Added joystick deadzone setting
• Fixed sound for when climbing ladders
• Fixed an issue with some weapon sounds in first person
• Fixed a swim sound loop error
• Increased the damage of Helicopter Miniguns, AA guns, and Jet Cannons against infantry
• Increased the damage of Helicopter Miniguns against jeeps.
• Reduced the physics impact of AA guns and Jet Cannons, players under attack from these weapons should no longer lose control.
• Increased the damage of the 44 Magnum slightly.
• Increased the range and minimum damage of the .357 Round from the MP412 Rex.
• Increased the range of all .45cal and 9mm weapons.
• Slightly increased the range of the P90 and MP7 and PDW-R.
• Slightly increased the range of the 5.56mm PDW-R and decreased the minimum damage at long range.
• Slightly increased the minimum range of the Mk11, SVD, and M39 EMR 7.62mm rifles.
• Decreased the maximum damage and maximum range of the G3 and SCAR-H 7.62mm weapons.
• Reduced the damage from FIM-92 and SA-18 IGLA missiles against aircraft.
• Increased the damage and range of the 40mm BUCK rounds.
• Reduced the damage .50cal weapons do against Helicopters.
• Updated T90 canister shell tweaks to match Abrams canister shells
UI Changes (PC)
• Added round duration and ticket summary at EOR
• Advanced squad polish – should be more intuitive
• Significant changes to the Join Squad functionality (see below)
• Fixed a problem regarding keybindings while playing
• You should now get a better error message when being disconnected via Battlelog
---- Server Update Highlights
• EOD Bot exploit fix
• Several crash fixes
• Anti-stat padding measures taken, disallowing ranked servers to run obscure settings
• Improved team kill kick configuration
• Support for unranked servers. Unranked servers do not report players' scores to Battlelog, but server administrators can freely control all settings
-- Share your profile and stats with new Battlelog functionality
• Ability to share your Profile and Stats pages to Facebook, Google+, and Twitter
• User Profile and Stats pages on Battlelog can now be accessed without being signed in to Battlelog if you know a user's URL
• Single sign on from Battlelog to Origin. If you're not logged in to Origin and join a game server, Battlelog will automatically sign you in to Origin in the background and join the game server
-- Quick notes on Squad changes in the Nov 22 update
• Removed FIND ME A SQUAD option
• Allow players to join empty Squads alone, thus having 1/4 squad members
• Change order of options to LEAVE SQUAD, INV A FRIEND, SWITCH TEAM
• Disable Privacy flag when 1 man squad
• Reset Privacy flag from Private to Public when squad drops to 1 player
• All occupied Squads will now show up colored blue on the Squad Selection screen
• Players who choose not to join squads will also show up as Blue in the "Not in a Squad” line
• Squads that are currently empty will display as white -- if you wish to join an empty Squad, you can choose the first one marked with white text
-- A detailed look at Squad refinements
Today's PC client patch features numerous tweaks to Squad functionality and is part of our ongoing efforts to make it easier to play with friends and Platoon mates. These changes will also be implemented for consoles when we release the PlayStation 3 and Xbox 360 updates shortly. Stay tuned for the exact date of the console updates.
First, we need to look at how joining with Squads and Platoons affects the balance of teams. Initially, servers are commanded to equal out each side, so joining with friends can impact that balance while joining with Platoons further hinders this. As a result we have made some adjustments to the in-game Squad management screen.
For PC, you are now able to highlight the various Squads and select which one you wish to join by selecting a Squad and then clicking the Join Squad button. Please note that the Squad Privacy option still allows 2 man Squads which, during 64 player sessions, can lead to players with no squad position –- the number of people with no Squads will be shown at the bottom of the Squad selection list.
After the patch is applied to consoles (in the near future) you will be able to join Squads by cycling through the list and selecting which Squad you wish to join.
Posted in: News
Promoted from Patch details
Class Action Lawsuit Over BF1943
21 November 2011 - 05:59 AM Posted By neged 28
You may remember at E3 when EA promised BF1943 to those PS3 players who pre-ordered Battlefield 3. You may also remember last month when EA announced on Twitter that the promised offer would no longer happen. Gamers were frustrated with EA's decision, but the offer took place in lieu of PS3 customers getting Battlefield 3 DLC one week early. This one week early PS3 exclusive will also be valid with the Back to Karkand expansion pack.
Gamers were happy when finding about the exclusivity, but the Edelson McGuire law firm is calling out EA on it's misleading claims. They allege that EA "misled and profited from thousands of their customers by making a promise that they could not, and never intended, to keep." One other point that has enraged Battlefield 3 gamers is that EA's announcement took place on the 25th, after the game had already been released. The announcement being late was also poorly announced, a simple Twitter message instead of a more formal, global email. It will be interesting to see how this class action lawsuit unfolds and how it will affect Battlefield 3.
via Kotaku
Posted in: News
Promoted from Class Action Lawsuit Over BF1943
Battlefield 3 Update - Incoming
18 November 2011 - 11:48 PM Posted By neged 27
We aren't getting specific details for EA's latest Battlefield 3 patch, but we're at least getting a few more details. Next week players will be graced with a full list of fixes and the new patch. PC players will be getting the Battlefield 3 update earlier than console players because of certification requirements by console developers. The list of updates include: improved polish, stability, weapons balancing, squad control functionality, user interface enhancements, and several feature enhancements that address feedback the community has provided to date. PC players will also benefit with a fix for the "negative mouse acceleration" bug. A big topic has been the IRNV scope being overpowered, the scope will be more balanced along with the SCAR rifle. In an interview with Gamespy, KM Troedsson acknowledged that DICE is aware of PC players' complaints about the overly intrusive chatbox and near useless comma-rose. Check out a fist of likely Battlefield 3 fixes here.
The overpowered IRNV scope and flashlight are big topics on DICE's list of fixes.
Cheating is also a big topic for the BF3 developers and are encouraging the community to click the report button (a ! on the user's Battlelog) to bring cheater's to DICE's attention.
Posted in: News
Promoted from Battlefield 3 Update - Incoming
New Strike at Karkand Trailer
18 November 2011 - 05:39 PM Posted By neged 28
Back to Karkand is due out next month and to tease us more, the Battlefield 3 developers have released a Strike at Karkand trailer. The teaser offers up another minute and a half of new Karkand footage. If you're a BF2 veteran, you'll quickly notice the new Battlefield 3 style and should be relieved that the map hasn't changed to much.
Posted in: News
Promoted from New Strike at Karkand Trailer
Battlefield 3 Patch Information - Coming Soon
15 November 2011 - 09:53 PM Posted By neged 17
Battlefield 3's launch was met by the community with two things: love and bugs. The bugs have been prominent on all platforms and have slowly been fixed by server updates. There are many that still have yet to be addressed though. A potential list of Battlefield 3 issues has been provided, but with no date. Daniel "zh1nt0" Matros revealed on the EA forums that a full list of fixes will be released later this week or early next week. The date is not finalized, stating that the dev team has a few dates going around. Still no date on the launch of this Battlefield 3 patch, but at least we will be receiving a full list of fixes very soon.
zh1nt0 said:
A fixlist will be posted sometime this week or at the latest early next week. Being very vague with deadlines here since we have a few dates going around.
Posted in: News
Promoted from Battlefield 3 Patch Information - Coming Soon
Battlefield 3 - Best Selling Game In October
14 November 2011 - 07:25 PM Posted By neged 12
NDP Group, a US based firm that deals with financial statistics revealed that Battlefield 3 was the top selling game in the US for the month of October. EA reported that Battlefield 3 had sold five million units worldwide in it's first week. Battlefield 3's figures are still far behind it's competitors, but the gap is still closing between the two games. There's even proof of the gap being closed. Eurogamer reports that MW3's sales are under two million in the UK - a 1.6% drop from Black Ops' sales last year. Battlefield 3's first piece of DLC "Back to Karkand" is due out next month, so that will also help to boost BF3's quickly growing player count.
Posted in: News
Promoted from Battlefield 3 - Best Selling Game In October
EA is taking serious actions towards cheaters and exploiters
11 November 2011 - 08:28 PM Posted By GRS 24
Posted in: News
Promoted from EA is taking serious actions towards cheaters and exploiters
List of Battlefield 3 Issues To Be Addressed
11 November 2011 - 06:52 PM Posted By neged 48
Battlefield 3's launch was smooth in most regards with only a few network hick-ups causing gameplay issues. There have been some control and balance issues that have been brought up by the community will also be addressed. Here's a list of issues addressed in the next Battlefield 3 patch:
There has been no set date for the latest patch, but the above issue list will probably be longer once the patch is released for Battlefield 3.
Posted in: News
Promoted from List of Battlefield 3 Issues To Be Addressed
Unlock Battlefield 3's MAV In Real-Life
11 November 2011 - 03:18 AM Posted By neged 11
Feel the need to spy on your neighborhood, Area 51, or something else? If you've played Battlefield 3, you might think of the
unlock. This little gadget can earn you a ton of quick and easy points in BF3. Their main role is recon and their real-life counter part "T-Hawk Micro Air Vehicle" built by Honeywell does just that.
The MAV looks oddly similar to it's BF3 counterpart.
The only difference is that the real one costs upwards of $200,000 where the Battlefield 3 version takes a few hours of gameplay.
Posted in: News
Promoted from Unlock Battlefield 3's MAV In Real-Life
<a href="http://www.enterbf3.com/news/631-crashing-a-lot-in-battlefield-3/" itemprop="url">Crashing A Lot In Battlefield 3?
11 November 2011 - 02:26 AM Posted By neged 10 Are you a PC player with an nVidia powered computer who's having issues with your Battlefield 3 performance? It could be your video card. More often than not, your video card drivers are out of date and are causing your game to feel sluggish and laggy. Updating your drivers may help your experience while playing Battlefield 3. nVidia released their most recent drivers (285.79) today. It fixes specific issues with BF3 such as:
Quote
  • Fixes cases of irregular performance (stuttering) primarily seen on DirectX 10 GPUs. The fix improves the performance of both DX10 and DX11 GPUs.
  • Fixes shadow map corruption seen with DirectX 10 GPUs.
  • Fixes cases of black corruption lines/triangles with DirectX 10 GPUs.
You can update your nVidia drivers here: http://www.geforce.c...rivers-released. Please remember that these drivers are beta and may not be supported by all nVidia systems. If you run ATI/AMD check here for the latest drivers. Updating other drivers, such as your audio drivers may also help your BF3 performance. You can also find support for the game in our Battlefield 3 Support forums.
Posted in: News
Promoted from Crashing A Lot In Battlefield 3?
Categories
Recent Articles
Recent Topics
Go to Forums
Recent Posts
Go to Forums
  • Turboless
  • Member For: 14y 4m 3d
longest post ever, but I bet u didnt even realise. all u read was;
"Fixed multiple problems when using multiple monitors (Eyefinity / Surround)." ;)
haha but nah this looks like an awesome update. im keen to get back n playing moar bf3 >=]
seriously... that 100% correct shy... now I wanna have some sex with dillz... because we are in love
  • Member For: 18y 9m 2d
I bought it of ebay so ill have it in a day or 2.. Paid 60 instead of the 99 jb was asking
f*ck waiting. I woulda paid $200 to get it a week early.
Well I cant play now after the update. They have stuffed it. Ive spent a long time defending this game against cod fanbois sayin its a fail since the beta. Right now im swallowing my pride and agreeing with them. They have failed to release a top shelf fps. I think the beta should not have been released, its now in beta stage. Mw2 was almost bug free from its release day. Dice have failed.
Yeah I paid 53.. that's with free postage.. The extra I paid was for express ;)
You made me buy it and it doesnt work now?
Edited by freeze_dk
