dragonf6 Member 17 Member For: 14y 1m 14d Posted 24/09/11 09:43 AM Share Posted 24/09/11 09:43 AM I've got a fg f6 currently with a 4" dump, outlaw high flow cat, standard exhaust from cat back and VCM HP tune running 11 psi. It's running around 300 - 310rwkw at the moment. After much research on this site and asking lots of questions it's going in for a process west stage 2 intercooler & retune shortly, as that's probably the best bang for the buck.I'm not chasing big numbers, probably around 330 - 340rwkw.My questions:1. With the above parts, is there a real/genuine need to put a cat back system on the car & what kw gain will that actually have verses leaving the exhaust standard from cat back? (will it make adiffernce at all)2. If I go for a cat back exhaust I thought a mild steel twin 2.5 as don't want any drone or noise or perhaps a 3.5 single. Thoughts? (mild steel because I'm turning the car over in 3 years)Out of interest, this is what's been quoted: :$2200.00 fitted for the stage 2 PW IC.$600.00 for the retunetune (vcm hp)Varying numbers on exhaust: 1. $2100 for 3.5 single custom SS cat back exhaust, 2. $795 for mild steel twin, 3. $900 for mild steel twin, 4. $1200 for 3.5 single Xforce - which to go for if I go that way?injectors (If there's a need) - buy from ebay & local mechanic will fit for $100.00. Tuners quoted $800.00 for this - go figure?Any comments thoughts on my questions would be appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/ Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 17d Gender: Male Location: Christchurch, New Zealand Posted 24/09/11 09:51 AM Share Posted 24/09/11 09:51 AM Doing the catback will allow the exhaust to flow easier which could in turn give you the power you want at a lower boost, or more power at the same boost. As for what to get everyone has different wants, I have stainless steel dump connected to mild steel catback and really like the noise it does have when booting it, general driving you can still sneak round. Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1143641 Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 14y 2m 27d Gender: Male Location: Gold Coast Posted 24/09/11 10:37 PM Share Posted 24/09/11 10:37 PM I would guess the $800 price tag for injectors includes a dyno tune. Not sure if Larger injectors are "plug & play" ? Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1143721 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 3m 15d Gender: Male Location: Vic Posted 25/09/11 01:51 AM Share Posted 25/09/11 01:51 AM for 330-340 you don't need it, but at my level its worth about 40rwkw if I upgrade the catback. Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1143753 Share on other sites More sharing options...
dragonf6 Member 17 Member For: 14y 1m 14d Posted 25/09/11 05:33 AM Author Share Posted 25/09/11 05:33 AM How is a cat back exhaust, regardless of configeration, 3.5 single or 2.5 twin etc etc, going to add 40kw? I thought that other peformance add ons like intercooler, dump pipe, cat, tune and turbo psi that make the most gains kw wise.Of course everyhing works together.There are cars on here runing relatively high rwkw's with standard cat back exhausts. I thought I could do the same and that an exhaust, kw wise, would add modest gains to the existing rwkw.Anyone know what kw gains a cat back exhaust on it's own will actually add?Thoughts?Oops, the $895 quotes for injectors actually was for purchase and fitting only. Tune was extra. Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1143806 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 3m 15d Gender: Male Location: Vic Posted 25/09/11 05:41 AM Share Posted 25/09/11 05:41 AM Because I have done pretty much everything else, the catback is that much of a restriction that it is holding it back. When I do the catback it should go from 360 to wherever the turbo max's out, hopefully 400.On its own without a tune there wouldnt be much of a gain, maybe 10kw? Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1143810 Share on other sites More sharing options...
Lazz1007 New Member 12 Member For: 13y 8m 18d Gender: Male Location: Perth Posted 30/10/11 12:29 PM Share Posted 30/10/11 12:29 PM I just recently bought a 2008 fg turbo. I drove out of the dealership and drove straight to Genie exhaust and Dyno, in Perth WA. They fitted a 2.5 inch X force, stainless cat back exhaust and K@N panel filter.It was dyno'd @ 264 rwks and 355 rwhp. Due to a double booking they couldnt do a pre fitment dyno unless I re booked for another day. So, I said fu$k it, and just do the final dyno and see where I stand " I didnt want to wait". Going by what most people say, the fg xr6t puts out about 220 to 240 rwks stock standard. So...... I reckon that's a pretty good result for a non tuned car. Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1155073 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 5m 17d Gender: Male Location: Auckland, New Zealand Posted 01/11/11 06:17 AM Share Posted 01/11/11 06:17 AM Non tuned? So you upgraded the exhaust without a tune and made good gains? If that's the case does it mean the engine is getting more air so running leaner?Just wondering because I upgraded my exhaust recently and was told not to go hard for long periods until it was tuned. Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1155555 Share on other sites More sharing options...
MurdoK Donating Members 719 Member For: 15y 14d Gender: Male Location: Perth,WA Posted 01/11/11 04:33 PM Share Posted 01/11/11 04:33 PM ^^^I think with standard FG dump and cat still in place it would be fine. Stock restrictive cat would help prevent overboosting and wont mess the ECU around thinking it needs to lean out to meet emissions. Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1155719 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 8m 9d Gender: Male Location: Far north queensland Posted 01/11/11 09:22 PM Share Posted 01/11/11 09:22 PM How is a cat back exhaust, regardless of configeration, 3.5 single or 2.5 twin etc etc, going to add 40kw? I thought that other peformance add ons like intercooler, dump pipe, cat, tune and turbo psi that make the most gains kw wise.There are cars on here runing relatively high rwkw's with standard cat back exhausts. I thought I could do the same and that an exhaust, kw wise, would add modest gains to the existing rwkw.The most restrictive link in the whole system is what will net you the most gains. For example if you have a bog stock BF.1st thing holding it back it the tune, but if you just tune it then the 2nd thing holding it back would be injectors, change them and retune and it will be your cat convertor or fuel pump or standard intercooler, change them and it just shifts it to another link in the system.If you look at henz's sig than he's got a lot of supporting mods, debatable on if just a good 3.5 - 4" system would net him 398rwkw but the stock cat back would definetly be the restriction in his system. Link to comment https://www.fordxr6turbo.com/forum/topic/77060-what-difference-kw-is-a-cat-back-exhaust-really-going-to-make/#findComment-1155743 Share on other sites More sharing options...
