Shift Light Install
Scott Tisco
  • Menace
  • Member For: 13y 7m 28d
open up the web page below. I got the 1 up the top left but that was the choice he gave me.
When you buy it you just give your car model and what not.
The LEDS are totally adjustable as in you can have the 1st 1 come on at say 3600rpm and then then progressto the last 1 that may come on at 5600rpm or how ever you want to do it.
Im just gunna mount mine on the steering wheel with double sided sticky tape that way I can quickly move it if I need to. Shold have it fitted up by wednesday.
http://www.ecliptech.com.au/index.php?option=com_virtuemart&page=shop.browse&category_id=2&Itemid=113&vmcchk=1&Itemid=113
  • 2 months later...
  • You've changed man....
  • Member For: 13y 11m 22d
bit of a bitch to get working 100% right but
thanks to headsex canbus interface :) its all spot on now and plug n go
his canbus interface "listens" to the RPM messages from the PCM to the Dash which occurs every 20ms.
It then outputs a Frequency as per a conventional Distributor based vehicle does.
This allows multiple amounts of aftermarket Tachos to be connected to a Aussie Ford Vehicle without any cutting / splicing into any wiring harness.
basically its an obd to pulse output for "any" shiftlight.... genius
Edited by STAINOnegger
  • Member For: 15y 7m 11d
I have one of these shift lights and it confused the hell out of me so it is still sitting in the garage.
In short, did you connect your signal wire to a wire from the ECU or use some sort of interface?
  • Member For: 16y 8m 29d
Staino uses interface now. Mine is wired in. I have no idea how to adjust t though.
  • Like 2
I installed mine into my FG today, exactly the same as the BA-BF by the looks of everything.
It all seems to work fine until it gets to 4500 and everything flashes, doesnt matter how I adjust it.
Any ideas?
