Xcal 3 Datalogging
Kroozin
  • Member For: 19y 7m 12d
Use your X2 for logging. Ensure 'rapid packet' is enabled if you have a BF. The old livelink versions 4.1 to 5.1 and x2's were faultless. 6.4 irritates me and interferes with AdvantageIII I you're tuning & logging. Hang in there!
p.s. Your high speed fan should be active at that coolant temp!
  • Menace
  • Member For: 13y 9m 29d
Timmy-XR6T when you say it then started onto the drivers installation had you not plugged in the xcal at this stage?
The Xcal icon only shows up in the device manager when I have it plugged in. It has the yellow exclaimation mark on it. Have already tried right clicking and selecting update driver but it only comes up with automatically find using windows blh blah or find it manually.
I will try and find it manually tomorrow when I get hm thru those files u mentioned thanks mate.
Failing that will try and re-install http://api.viglink.c..._13171136018661 from this link.
IH8TOADS I got this sent to me today about my car. Are you able to see from this if it isnt set right??
It looks like it must be in farenheit,, Down the bottom its has a speed of 30kph/hr or mp/hr dont know what that's about??
I plan on changing my tstat from a 72degree up to an 82degree hiflow as I believe 72 might be a tad cold.
What would be my ideal low fan cut in ........ and hi fan cut in........? And cut outs? Thanks fellas.
post-46011-0-00811800-1317114051_thumb.j
Edited by Kroozin
  • Member For: 15y 1m 2d
Wonder if the high speed fan switch that is set to 1 has anything to do with it. It should be coming on when there is only an 11 deg split between the fans coming on.
I could tell you, but what about the rest of the tune........
I'm not blowing wind up their behind but guys like Pitlane etc are well respected for a reason and live and breathe this stuff.
  • Menace
It could be just a simple mistake though guys.
The rest of the tune feels smooth as, there is no hesitation anywhere, no audible pinging, feels just as quick as the day it was tuned and no carbon on the back of the car anymore. I'm actually very happy with the way it drives its just this fan issue.
  • Menace
search for this file :
c:\windows\system32\drivers\SCTdriver\v1011.sys
this is the file that its looking for
Thanx quadie I'll check it out when I get back from work
