Best Cooler Upgrade Using Standard Piping
Ale
  • Member For: 17y 7m 18d
Agreed, the stock pipes are mainly 2 inch inside. I believe at least 2.5/2.75 is needed to help airspeed and drag for decent power...pretty much gotta change everything no stock look, new front pipe for boost sensor etc etc. Dont see the point
Missed this one, It's the stock hot side pipe to the cooler that is the main culprit for huge restrictions in the standard system. As crap as the crossover and pipes from the turbo up look they will flow the boost you need.
From memory I think a 10 second pass has been done with stock crossover just to illustrate that fact.
But ideally the better the flow the less boost you need to make power, which is safer for your engine.
  • Replies 31
  • Bronze Donating Members
  • Member For: 13y 8m 25d
coolerworx make them for BA/BF there on eBay
I thought id add this in here as its relevant does anyone know of a company that does replacement stock piping in metal replacing the factory stuff but leaving the crossover in its standard position as I think alot of people would like this option to keep everything looking factory.
Edited by 0096FPV
