Zf Gear Change
XRTFG6
  • Member For: 13y 11m 14d
What rpm dose the engine rev out to before changing gears say from second to third in standard drive selection when it's foot floored eg 6000rpm
On the track of course :)
Edited by XRTFG6
  • Member For: 17y 2m
After having it tuned it tends to hit the limiter in the lower gears from what I hear. I shift in manual mode 99% of the time for that reason and due to it being more amusing. Hopefully someone who uses auto mode to redline will comment...
Yea I've had mine tuned and. Now in the lower gears it want to rev out to around the 6500rpm mark before changing gears so it looks like I'll be using the Manuel mode from now just wanted to now if anyone else is having this
Rev limiter has been raised as well then? Might not be safe unless you have a built/balanced engine?
