  • Replies 31
  • Member For: 17y 1m 13d
What changes was he making, settings he's chosen or you've asked for?
Owmuchisit?
https://www.fordxr6turbo.com/forum/topic/76929-zf-flashed/#findComment-1141052
  • Member For: 16y 2m 2d
Ok, first drive out from the tuners I was immediately not impressed. A sharp judd as the car changes gears which is not what im used too. The rest is perfect but im not liking the hard changes on light throttle. Changes are much much faster in light throttle so maybe I have to compromise. Full throttle is very nice and crisp.
I'll check in peak hour traffic tomorrow.
Might have to turn down the sharpiness if I dont like it.
https://www.fordxr6turbo.com/forum/topic/76929-zf-flashed/#findComment-1141097
  • Member For: 17y 5m 9d
Shouldn't* :P
That doesn't sound to cool, can't it be made smooth in D and sharp in perf/manual? I'm sure I remember reading that. I drive in manual mode all the time though so I'd need it linked to RPM...soft if I shift at low RPM and sharp if I'm getting up it.
Will keep an eye on your developments Robo.
https://www.fordxr6turbo.com/forum/topic/76929-zf-flashed/#findComment-1141104
  • Moar Powar Babeh
  • Member For: 19y 7m 10d
Que'...??
Don't the ZF's have 11(?) different shift profiles? Steve I would assume shift firmness would be based on multiple factors and perf mode would def be one along with rpm/load/road speed etc etc
https://www.fordxr6turbo.com/forum/topic/76929-zf-flashed/#findComment-1141107
Yeah they are supposed to be smart, and there are a lot of variables in the software...
I'd hope it senses commanded throttle, road speed and RPM so it knows what you're up to...lazy or hammering. The whole 200 point scale thing it's got.
PS If you edit your post at least edit mine to remove the correction :P
LUKE IS YOUR OVERLORD
Hey that's not a nice edit either!
Edited by -SteveR-
https://www.fordxr6turbo.com/forum/topic/76929-zf-flashed/#findComment-1141116
  • Member For: 18y 11m 6d
The ZF has 50 different shift profiles, they are numbered and not labled to what they do and the auto does not report to what profile is being used at what point
https://www.fordxr6turbo.com/forum/topic/76929-zf-flashed/#findComment-1141198
  • Member For: 19y 9m 15d
I'd least hope that you could have the best of both worlds, smooth, soft shifts when driving gently and a firmer,more positive shift when you're right up it.. Given the sophistication of the trans and its inherent capabilites, this should be approachable I'd imagine?
https://www.fordxr6turbo.com/forum/topic/76929-zf-flashed/#findComment-1141399
