Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 28d Gender: Male Location: Victoria Posted 11/05/12 06:43 AM Share Posted 11/05/12 06:43 AM Why not use the Nulon oil which has ZF approval, unlike all the others? Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235413 Share on other sites More sharing options...
Rossnall Bronze Donating Members 72 Member For: 13y 20d Gender: Male Location: Bundaberg, QLD Posted 11/05/12 07:53 AM Share Posted 11/05/12 07:53 AM (edited) On 11/05/2012 at 6:43 AM, Adam said: Why not use the Nulon oil which has ZF approval, unlike all the others?Suitable, not approved. Sorry for being pedantic, but big difference in whose ass is on the line if something goes wrong. Edited 11/05/12 07:54 AM by Rossnall Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235463 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 13d Posted 11/05/12 08:40 AM Share Posted 11/05/12 08:40 AM On 11/05/2012 at 6:43 AM, Adam said: Why not use the Nulon oil which has ZF approval, unlike all the others?GW print on their 20l drum sticker theirs is approved for the Ford ZF 6 spd in BF & FG...And yes they use the word approved Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235512 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 1d Gender: Male Location: SE Melbourne Posted 11/05/12 08:45 AM Share Posted 11/05/12 08:45 AM (edited) On 11/05/2012 at 2:49 AM, Wenier said: That rev hunt your talking (if I understood what you said correctly) is just the car running the rich startup cause its cold.Wrong.The box is actually commanding the PCM to do that. Edited 11/05/12 08:45 AM by Paulie2256 Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235516 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 13d Posted 11/05/12 09:11 AM Share Posted 11/05/12 09:11 AM On 11/05/2012 at 8:45 AM, Paulie2256 said: Wrong.The box is actually commanding the PCM to do that.Why would it do that though, any ideas?I read another member who had the same problem, monsta torque suggested it had previously had water contamination and the torque converter may be damaged. Ford checked for fault codes and it only said clutch slip.Water contamination does cause hunting too, riptide had it, his was all the time though Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235537 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 1d Gender: Male Location: SE Melbourne Posted 11/05/12 09:49 AM Share Posted 11/05/12 09:49 AM It could be a number of things like converter is trying to lock up early or incorrect oil temp reading. It's not easy to diagnose over the net. Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235559 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 28d Gender: Male Location: Victoria Posted 11/05/12 10:26 AM Share Posted 11/05/12 10:26 AM On 11/05/2012 at 7:53 AM, Rossnall said: Suitable, not approved. Sorry for being pedantic, but big difference in whose ass is on the line if something goes wrong.Fair point. I assumed the title of the other thread was correct.I used the genuine oil for my service and will continue to do so. Not worth the risk not to IMO. Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235584 Share on other sites More sharing options...
SPOOLAX Skids? Donating Members 975 Member For: 15y 11m 16d Gender: Male Location: Adelaide Posted 11/05/12 12:31 PM Share Posted 11/05/12 12:31 PM On 11/05/2012 at 7:53 AM, Rossnall said: Suitable, not approved. Sorry for being pedantic, but big difference in whose ass is on the line if something goes wrong.Im going to use Nulon next time! Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235715 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 5d Gender: Male Location: Christchurch, New Zealand Posted 12/05/12 01:02 AM Share Posted 12/05/12 01:02 AM On 11/05/2012 at 8:45 AM, Paulie2256 said: The box is actually commanding the PCM to do that.So what is the reasoning for the PCM doing it?I know that run a rich cycle on start for a little bit which also shows in the revs, whats the PCM one about. Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235878 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 1d Gender: Male Location: SE Melbourne Posted 12/05/12 01:20 AM Share Posted 12/05/12 01:20 AM (edited) The rich cycle is open loop and it bypasses the o2 sensor and runs a different fuel map. Since its a static map, revvs shouldn't hunt. Not sure if our map sensor and coolant temp is used to calculate AFR in this case but if they are the. Maybe one of those is faulty. Edited 12/05/12 01:23 AM by Paulie2256 Link to comment https://www.fordxr6turbo.com/forum/topic/76845-zf-serviced/page/9/#findComment-1235882 Share on other sites More sharing options...
