shaneo_1 Member 108 Member For: 17y 11m 19d Posted 09/09/11 08:53 PM Share Posted 09/09/11 08:53 PM I am currently putting a bigger turbo on my bf mk1 and still stock bottom end, I dont really wanan invest in an atomic bottom end and was wondering, if I only put a decent set of rods in what sorta power could it handle with stock pistons?or if I just do rods and pistons?just dont really wanna put to much more dollers into it, just need piece of mind that the rods wont break, wanna make 450rwkw I am thinking. Link to comment Share on other sites More sharing options...
XAH03 Member 597 Member For: 17y 3m 25d Gender: Male Location: Cairns QLD Posted 09/09/11 10:23 PM Share Posted 09/09/11 10:23 PM If you've got it apart you may aswell do the pistons. Do the oil pump too. Link to comment Share on other sites More sharing options...
Pheared Banned 37 Member For: 13y 6m 9d Gender: Male Posted 10/09/11 05:28 AM Share Posted 10/09/11 05:28 AM if you do one thing, you SHOULD do the rest 'for piece of mind' Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 7m 29d Gender: Male Location: south east suburbs Posted 10/09/11 06:34 AM Share Posted 10/09/11 06:34 AM Your better off doing pistons as well if your pushing 450, mind you, these are a bare minimum, there is no real cheap way out of it though, just rods and pistons will set you back a small fortune, theres other things to consider also and it will add up fairly quickly. Take into account labour if your not doing it yourself.Be prepared for a shock if you want to do it on the cheap side. Let alone properly. Link to comment Share on other sites More sharing options...
