Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 10m 15d Gender: Male Location: Vic Posted 07/09/11 09:41 PM Share Posted 07/09/11 09:41 PM I gave Mick my $5 and said keep the change. I'm a little bit generous like that. Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 5m 16d Gender: Male Location: Zombie Birdhouse Posted 08/09/11 03:21 AM Share Posted 08/09/11 03:21 AM stock clutch Will be fine mate.That is just bullsh*t. 300 atw and OK ? Not for long Even the stock AP twin plate in the Phoons struggle @ 300+ Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 10m 15d Gender: Male Location: Vic Posted 08/09/11 04:21 AM Share Posted 08/09/11 04:21 AM L to drive. Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 1m 8d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 08/09/11 04:25 AM Share Posted 08/09/11 04:25 AM With stupid Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 8m 9d Gender: Male Location: Melbourne Posted 08/09/11 09:22 AM Share Posted 08/09/11 09:22 AM Buy all parts second hand from the forum. Get a nice dump (4" most likely), 'high flow' cat, basic cooler kit (any of the reputable names), injectors (42lb or bigger) and intank pump. XCAL3. The only part you have to pay new for is the tune I have nizpro cooler second hand with replacement cold side piping to stock crossover, F6 intake snorkel on stock airbox, K&N filter (also my first mod), 42lb squirters and a full exahust in 2x2.5 with a 3.5" split dump and twin cats...that exhaust was bought new though and wasn't required being a BFII from what I gather. It's way louder now, far deeper note, so don't do that if you're trying to hide it!All up I paid about $5100 including XCAL and tune but I reckon you could do it for 3k if you buy wisely and have patience. See my sig for results.OH you have a manual...clutch will sh*t itself with 300rwkw, budget for upgrade or you can't use the power. Stock ZF FTW Good advice, that's what I'm doing. If I can hit 300 that would be great but doing it on a decent dollar would be even better. Bit of a challenge. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 10d Gender: Male Location: Probably above atmospheric pressure Posted 08/09/11 01:17 PM Share Posted 08/09/11 01:17 PM I got my cooler and piping for $1110 posted which was good (have seen nizzy and pipes even cheaper on here since), but blew it on exhaust hahaha! Good luck. I tried to stick to top quality parts hence going Nizpro and Manta which made it harder. Performance hasn't ever faltered though! Link to comment Share on other sites More sharing options...
Emosh99 Member 260 Member For: 14y 1m 16d Gender: Male Location: Melb Posted 09/09/11 12:47 AM Share Posted 09/09/11 12:47 AM (edited) Just made 310 on 12.5psi withHdi coolerPlazaman under battery intakeOutlaw 5" catXcal 360lb dekasNo middle mufflerNew bkr6e ix Low temp thermostat Tuned by Mick @ pitlane Edited 09/09/11 12:50 AM by Emosh99 Link to comment Share on other sites More sharing options...
mfoulds83 Member 8 Member For: 15y 2m 11d Gender: Male Location: Melbourne Posted 09/09/11 12:55 AM Author Share Posted 09/09/11 12:55 AM how much did that set you back emosh? I was leaning toward going to pitlane for my upgrade Link to comment Share on other sites More sharing options...
Emosh99 Member 260 Member For: 14y 1m 16d Gender: Male Location: Melb Posted 09/09/11 03:08 AM Share Posted 09/09/11 03:08 AM I have edited below on what you should expect to pay, I can't remember all but they are close enough. I saved a bunch in labour in doing everything myself except the injectors and exhaust. If your not mechanically minded I would strongly recommend a workshop to do it for you as if you haven't done something properly, your tuner may have to do it again properly this time. I highly recommend Mick, I live 2 hours away from pitlane but was well worth my travel. Just made 310 on 12.5psi withHdi cooler - $500ish 2nd hand Plazaman under battery intake $250-300ish 2nd handOutlaw 5" cat - $250 for cat $120 to fit it with provisions for force gear down the track Hallam exhasutsXcal 3 - brand new $800 60lb dekas $510 brand new fittedNo middle muffler $80 Hallam exhasuts ask for Barney tell him Eddie with the gray ute sent yaNew bkr6e ix $90 off eBay Low temp thermostat 30Tuned by Mick @ pitlane $800 Link to comment Share on other sites More sharing options...
mfoulds83 Member 8 Member For: 15y 2m 11d Gender: Male Location: Melbourne Posted 12/09/11 02:21 AM Author Share Posted 12/09/11 02:21 AM Cheers mate much appreciated. that sounds good to me. ill leave in the middle muffler as to keep the noise down but otherwise the rest sounds affordable and exciting Link to comment Share on other sites More sharing options...
