arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m Gender: Male Location: Perth Posted 18/11/17 11:35 AM Share Posted 18/11/17 11:35 AM On 06/09/2011 at 8:40 AM, Mr Man said: pretty sure the fill hole is about 4L, so you need an extra 800ml through the reverse switch... Expand Fill through the fill hole, jack the car on an angle and the other 800mls goes in , no need to remove reverse switch. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/page/3/#findComment-1647269 Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 6m 24d Gender: Male Location: Rockhampton Qld Posted 18/11/17 10:35 PM Share Posted 18/11/17 10:35 PM Or you can remove the shifter n go from the top. Just need a big funnel so you dont spill gear oil inside your car Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/page/3/#findComment-1647279 Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 10y 2m 20d Posted 19/11/17 02:30 AM Share Posted 19/11/17 02:30 AM Does Transmax Z come in 5 ltr bottles. Or have they got the scam going that you need to buy two 4 ltr bottles? Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/page/3/#findComment-1647281 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,573 Member For: 17y 2m 17d Gender: Male Location: Melbourne Posted 19/11/17 02:36 AM Share Posted 19/11/17 02:36 AM I haven't looked around in quite a while, but I think it was discontinued.. On 18/11/2017 at 10:15 AM, joffa1 said: Anyone know what size ring Spanner/socket is required to get the reverse switch nut off once the wiring is removed? Expand I just checked to confirm, and it's 22mm. What arronm said, is true, you can do it that way, too. Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/page/3/#findComment-1647282 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m Gender: Male Location: Perth Posted 19/11/17 02:47 AM Share Posted 19/11/17 02:47 AM Just use gulf western syn TS. Same as the ZF oil. Its full synthetic, that's what you want in a gearbox, an oil that is resistant to shear. Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/page/3/#findComment-1647283 Share on other sites More sharing options...
joffa1 Member 163 Member For: 7y 11m 15d Posted 19/11/17 05:55 AM Share Posted 19/11/17 05:55 AM Thanks guys didn’t have the right size Spanner/socket handy so ended up going through the shifter. Bit of practice for when I put a short shifter in anyway. I tried the jack one side right up but found I still couldn’t get the full 4.85 in without spilling out the fill hole. All good now, have some fresh Penrite full synth 70-75w pro gear in and it has quitened the box right down. Hopefully cold shifts a bit better now too. Did the diff oil while I was down there too... black and stinky don’t know how the thing was still spinning! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/page/3/#findComment-1647286 Share on other sites More sharing options...
