beau-s Member 6 Member For: 14y 4m 22d Posted 05/09/11 08:34 AM Share Posted 05/09/11 08:34 AM hey guys how are you?I know this has probably been covered a few times before but I couldnt find anything definate..I have a BA MK2 6 speed manual and have noticed a bit of a oil leak coming from the gearbox, took it to a gearbox and diff specialist to be fixed.How much oil should be put into this gearbox?Ive rang heaps of places, with different answers - Ford dealer 1 - just fill to fill plug Ford dealer 2 - fill using the drain plug?? (apparantly they have a special tool to do it) heaps of performance shops and they all just fill to the fill plug.should I add extra oil to the box or is to the fill plug enough?? and if so, where from? I tried removing the reverse switch but couldnt get a spanner to fit on it without fouling on the box??any help would be GREATLY appreciated, and im really sorry if this has been covered before, its just really confusing..Beau. Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/ Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 11m 11d Gender: Male Location: Brisbane Posted 05/09/11 09:11 AM Share Posted 05/09/11 09:11 AM Mate were are you from?Either a friendly Forumite or local sponsor may be able to help you out.Scotty Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1137978 Share on other sites More sharing options...
beau-s Member 6 Member For: 14y 4m 22d Posted 05/09/11 07:46 PM Author Share Posted 05/09/11 07:46 PM Hey scotty thanks heaps for your reply..I'm from penrith area Nsw.. Everyone I've talked to around here only fill to the plug.. Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1138096 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 10d Gender: Male Location: Christchurch, New Zealand Posted 05/09/11 10:26 PM Share Posted 05/09/11 10:26 PM Fill it through the reverse switch. If you remove the wiring from the switch you can get the ring end of a spanner of it and remove it, then I think it was 4.85L that should be put in the box through there, that is above the fill port but below the reverse switch hole.If you only go to the fill port I believe the box is quite noisy as the oil isn't covering enough to quieten it down. And xr8 have different amount to 6t.Hope this helps. Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1138111 Share on other sites More sharing options...
Mr Man Mad Scientist Member 816 Member For: 20y 6m 30d Gender: Male Location: Vic Posted 06/09/11 12:45 AM Share Posted 06/09/11 12:45 AM 4.8L of Transmax Z will do the trick, and fill through the reverse switch as stated above Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1138133 Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 18y 2m 12d Gender: Male Location: Sydney Posted 06/09/11 12:58 AM Share Posted 06/09/11 12:58 AM What others ha said, filling using the normal fill hole will make it a noisy b***h... Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1138134 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 6m 20d Gender: Male Location: CQ Posted 06/09/11 02:44 AM Share Posted 06/09/11 02:44 AM some people fill it through the normal fill hole with that side of the car jacked up a touch so you are able to put more then the 4L into it but I havent personally done that so I dont know how well it works. Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1138144 Share on other sites More sharing options...
beau-s Member 6 Member For: 14y 4m 22d Posted 06/09/11 08:22 AM Author Share Posted 06/09/11 08:22 AM Thanks heaps for the replys guys.. Isn't it weird that nobody at all knew that?? Even some very well known performance shops specializing in those cars.. Any one know how much extra oil I should be putting in through the switch?? I tried getting a 22 or 21mm ring spanner over the switch, but couldn't get it past where the wires themselves go into the switch.. Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1138243 Share on other sites More sharing options...
Slash Donkey Dick Member 801 Member For: 15y 3m 9d Gender: Male Posted 06/09/11 08:40 AM Share Posted 06/09/11 08:40 AM Just shy of 5L.Buy a fluid pump from Repco/Supercheap/Autopro etc, jack the car up slightly on driver's side, fill from drain hole. It's the easiest way & will take you literally 20mins to drain + re-fill. Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1138256 Share on other sites More sharing options...
Mr Man Mad Scientist Member 816 Member For: 20y 6m 30d Gender: Male Location: Vic Posted 06/09/11 08:40 AM Share Posted 06/09/11 08:40 AM pretty sure the fill hole is about 4L, so you need an extra 800ml through the reverse switch... Link to comment https://www.fordxr6turbo.com/forum/topic/76787-t56-gearbox-oil/#findComment-1138257 Share on other sites More sharing options...
