chad_22 Member 44 Member For: 18y 7m 16d Posted 05/09/11 05:56 AM Share Posted 05/09/11 05:56 AM hi guys,I understand that rough idle is pretty common on the ba turbos but cant help but think mine is a bit worse than the ordinary rough idle.When mine is in drive and I am idle, vibration can be felt through the whole cabin and I can see the drivers side rear view mirror shaking as well. When in neutral everything seems ok.I was told this could be engine mounts, around $1200 to replace through Ford or low idle. A mechanic that drove my car said my car is idling at around 500 where it should be at around 700rpm. Dont really want to spend $1200 if it isn't going to fix the issue.Has anyone had any experience with this, either resolving it by replacing mounts or adjusting the idle? Link to comment Share on other sites More sharing options...
xr6t4life Member 129 Member For: 15y 6m 6d Gender: Male Location: Perth WA Posted 05/09/11 06:09 AM Share Posted 05/09/11 06:09 AM clean your throttle body it should clear it up and while your cleaning it take your battery off to reset the computer Link to comment Share on other sites More sharing options...
chad_22 Member 44 Member For: 18y 7m 16d Posted 05/09/11 06:24 AM Author Share Posted 05/09/11 06:24 AM I had the throttle body cleaned about a year and a half ago so would it need to be cleaned that soon after?I had the battery out the other day and issue still persists so unfortunately that's not the problem. Link to comment Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 16y 11m 17d Gender: Male Location: Perth, WA Posted 08/09/11 06:47 AM Share Posted 08/09/11 06:47 AM Hey mate,Yeah definitely try to clean your TB again. At worse, all you've done is try the cheapest option first. Just use some carby cleaner and give it a good clean.Also put a bottle of fuel treatment through the car. I honestly don't know how good they are, but they are supposed to clean out the fuel system and make it more efficient. I did 3 or 4 things at once when my car had the rough idle, so I can't comment on how good an individual part was.Not saying that any of these are your problems, but I did the TB, cleaned out the air filters, spark plugs, fuel treatment and ignition coils. (Coils were more for the failing power under load)Mine was so bad that it would 'bottom' out at the lights when I pulled up. The revs would drop off and it would just turn off...How many KM's has your car got? Year? Mods? Link to comment Share on other sites More sharing options...
xhxrsix Member 174 Member For: 18y 2m 15d Gender: Male Location: Melbourne Posted 10/09/11 06:20 AM Share Posted 10/09/11 06:20 AM I had a vibration at idle an it finally got worse to the point where it felt like my clutch was stuffed, shuddering/vibrating on normal takeoff.. also felt as if the idle was low. Ended up being the drives side engine mount totally stuffed! $1200 seems a bit steep though. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 1m 29d Gender: Male Location: Probably above atmospheric pressure Posted 10/09/11 09:45 AM Share Posted 10/09/11 09:45 AM I'll have to go through the same list you did Dan, mine's copping bad idle from time to time now, mainly after urban start stop driving. Was yours consistent? Link to comment Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 16y 11m 17d Gender: Male Location: Perth, WA Posted 10/09/11 03:04 PM Share Posted 10/09/11 03:04 PM Yeah Steve,It was a little on and off, but the revs would drop almost every time I stopped. Especially at the bottom of first gear as it returned to 'idle' revs.Would just drop and the car would turn off... I also found as it got hot, like you say, it was worse... Dunno why though.Just to recap, I did;New NGK spark plugsCleaned Air filterCleaned Throttle body really wellFuel treatmentDisconnect/Reconnected battery (After a few hours)After that the idle stayed very consistent and didn't bottom out. Power was a lot more linear as well and along with the boost solenoid clean, it fixed all of my issues. Without the plugs, will set you back all of $20 and however long it takes to do! Chad, give these things a go mate and if they're no good then try the engine mounts. The TB causes all sorts of issues when it's gunked up... Link to comment Share on other sites More sharing options...
