PCW Donating Members 181 Member For: 17y 1m 25d Gender: Male Location: Melbourne Posted 03/09/11 02:30 AM Share Posted 03/09/11 02:30 AM Thought you guys may be interested in a recent CB antenna install I did.I was not wanting to put an external antenna or through glass UHF antenna and came across the Axis UHF brand that mounts inside on the windscreen that is a direct connection to the UHF CB.So far the performance has been great and am very happy for what I use it for. ( on highway listening and talking with other vehicles to see where traffic issues may be etc)Cost is around $50.00 plus install time.Cheers,Pete Link to comment https://www.fordxr6turbo.com/forum/topic/76746-uhf-cb-inside-on-glass-install/ Share on other sites More sharing options...
Shyfrd Turboless Donating Members 5,992 Member For: 14y 2m Gender: Male Location: Geelong, Victoria Posted 03/09/11 11:53 AM Share Posted 03/09/11 11:53 AM very nice mate! is it a pain being in your view even though its on the passenger side? and could it have been hidden stealthly behind the black area of the windscreen? Link to comment https://www.fordxr6turbo.com/forum/topic/76746-uhf-cb-inside-on-glass-install/#findComment-1137445 Share on other sites More sharing options...
PCW Donating Members 181 Member For: 17y 1m 25d Gender: Male Location: Melbourne Posted 04/09/11 02:10 AM Author Share Posted 04/09/11 02:10 AM its not bad where it is and although in line of sight for the passenger I think OK (it is just out of the sweep area of wiper). not sure if you can move closer as it actually indicates in the instructions to keep it 150mm away from the pillar.(Would possibly be a case of trying it closer to the pillar before final install to see if it makes a difference.)I mainly use if traveling in the bush to speak with trucks going in the opposite direct. (good to find out where the double ones are hiding)Pete Link to comment https://www.fordxr6turbo.com/forum/topic/76746-uhf-cb-inside-on-glass-install/#findComment-1137576 Share on other sites More sharing options...
