GeGe6 Donating Members 1,978 Member For: 12y 7m 11d Gender: Male Location: Perth, SOR Posted 13/11/14 07:41 AM Share Posted 13/11/14 07:41 AM Ok Bomber, I think you have talked me into a GTX.Mate did you purchase gasket nipple etc, at same time?Have you got part numbers? 1 Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 6m 12d Gender: Male Location: Adelaide Posted 13/11/14 08:02 AM Share Posted 13/11/14 08:02 AM use the nipple off the old turbo. new gaskets and copper washers from mtq will do the job 1 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 7d Gender: Male Location: Gold Coast Posted 13/11/14 09:58 AM Author Share Posted 13/11/14 09:58 AM (edited) The boys didn't put the nipple in the comp cover actually. They put them on the hot side pipe which MTQ recommended also as as they reckon it gives a better boost input to the solenoid. Edited 13/11/14 09:59 AM by Bomber Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 11y 10m 11d Gender: Male Location: A big bridge over a river in South Australia Posted 13/11/14 10:05 AM Share Posted 13/11/14 10:05 AM I remember someone else mentioning this Bomber .. can't remember who though.Any idea why or even how the solenoid likes it better? Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 7d Gender: Male Location: Gold Coast Posted 13/11/14 10:15 AM Author Share Posted 13/11/14 10:15 AM Because it's at the top/start of the snail in the narrow portion, it creates turbulence. Away from the cover that's not an issue. 1 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 7d Gender: Male Location: Gold Coast Posted 13/11/14 10:18 AM Author Share Posted 13/11/14 10:18 AM (edited) It's actually easier to put in the hot side also. Just drill out, back nut with lock tight on and done. Or if really fussy, get someone to weld a nut on but that's probably going overboard. Don't know if the alloy piping would be thick enough to drill and tap on it's own though. Maybe. Either way, easily done. Depending on where you put it, you may need a longer hose back to the solenoid. Edited 13/11/14 10:26 AM by Bomber Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 7m 11d Gender: Male Location: Perth, SOR Posted 13/11/14 03:02 PM Share Posted 13/11/14 03:02 PM Any Pics of this? 1 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 7d Gender: Male Location: Gold Coast Posted 13/11/14 11:05 PM Author Share Posted 13/11/14 11:05 PM (edited) So basically, just above where the silicon finishes on the hot side pipe. In this case, on the tube end at the front of the car for easy access. The good thing about this also is it removes any chance of getting alloy fillings in the comp cover or screwing up the thread taping etc. Much easier to get right in the tube or repair if any error is made. For those going full 'bling' it looks neater also. Edited 13/11/14 11:15 PM by Bomber 1 Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 7m 11d Gender: Male Location: Perth, SOR Posted 13/11/14 11:12 PM Share Posted 13/11/14 11:12 PM So that's hot side intercool pipe with nipple mounted to side? Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 7d Gender: Male Location: Gold Coast Posted 13/11/14 11:18 PM Author Share Posted 13/11/14 11:18 PM ^^^ correct. Worst case you may need a new rubber hose back to the solenoid if too short. 1 Link to comment Share on other sites More sharing options...
