Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 19d Gender: Male Location: Gold Coast Posted 09/07/14 10:20 AM Author Share Posted 09/07/14 10:20 AM ^^ hope so jimmixr. The product seems to be well respected and they were very helpful on the phone. The xforce catback bolts up to the venom with the 2 bolt OEM set up no problems so this should be no different I hope. Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 6m 11d Posted 09/07/14 01:52 PM Share Posted 09/07/14 01:52 PM Yep..your correct..2 bolt will allow factory system bolt straight up.. Had standard system on for over a year before I went custom 3.5Had mine coated and wrapped.. 1 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 19d Gender: Male Location: Gold Coast Posted 11/07/14 06:21 AM Author Share Posted 11/07/14 06:21 AM Very impressed with the quality. Has a mount off the side also to bolt to trans which is a good idea. 3 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 19d Gender: Male Location: Gold Coast Posted 11/07/14 09:01 AM Author Share Posted 11/07/14 09:01 AM 4 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 9m 26d Gender: Male Location: Central Coast Posted 11/07/14 09:07 AM Share Posted 11/07/14 09:07 AM Prettyyyyy 2 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 19d Gender: Male Location: Gold Coast Posted 11/07/14 09:27 AM Author Share Posted 11/07/14 09:27 AM I think the actuator needs to be rotated. Job for tomorrow. Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 7m 23d Gender: Male Location: Perth, SOR Posted 16/07/14 06:20 PM Share Posted 16/07/14 06:20 PM Must be close to tune time, don't keep us hanging! 1 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 19d Gender: Male Location: Gold Coast Posted 17/07/14 08:52 AM Author Share Posted 17/07/14 08:52 AM First run today but ran into a snag with the actuator. Came ready to fit but appears preload isn't right or we have another issue. Boys will sort it in the morning without too much fuss hopefully then tune it.Everything went well otherwise except the xforce flange that didn't align spot on so required adjustment. The Advance Dump & Cat combo is very well made. Has a transmission mount to stop the whole thing hanging off the turbo bolts which I like. Only criticism is I wish they'd put some all thread or mount for the lower heat shield bolt. Being the fussy *beep* I am, I'll probably get that done afterwards. Shouldn't be too hard to do given you can just mark the hole with a texta, remove the shields, then tack weld a bolt or rod on. Refit the shields put a nut on the bolt and done. 2 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 19d Gender: Male Location: Gold Coast Posted 18/07/14 07:52 AM Author Share Posted 18/07/14 07:52 AM Confirmed that it was a 7psi actuator supplied and fitted :( The guys put as much preload as possible and ran her up put could only make 13psi. However, was making 332rwkw at that Poo happens and MTA have admitted the error and have taken steps to correct it. New actuator will go on next week and a we'll put some boost into it. 2 Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 6m 11d Posted 18/07/14 07:58 AM Share Posted 18/07/14 07:58 AM Good to hear your happy with the advance dump.. hate recommending something sub standardShame about the actuator...But #$hit happens..Look fwd to the results as Im sure you are too 1 Link to comment Share on other sites More sharing options...
