In The Club
Bomber
  • Bronze Donating Members
  • Member For: 11y 10m 23d
That's what she said
Boom tish
  • Carnage on the Garage Floor
  • Member For: 14y 9m 19d
Really happy that the car is just about finished. Pretty rare that you actually exceed where you thought you'd take something. Didn't think I'd get the Brembos but did early this year and almost gave up on upgrading the turbo but will have that in a couple of weeks also.
The final mod list for the car will be:
PWR stepped intercooler
PWR Expansion Tank & ECU cover
PWR ZF heat exchanger
Plazmaman pipe kit
Plazmaman turbo side airbox & battery relocation
Process West throttle body elbow
MTA 750 (.50 cover)
Earls remote oil filter
ID1000 injectors
Herrod E85 spec 400lph intank fuel pump
xforce 2.5" twin s/s catback
Venom 4" s/s dump & 5" 100cpsi cat
PAC Racing Springs
Brembo 4 piston fronts & PBR upgrade rears
DBA T3 rotors
King SSL springs & Monroe GT Sport shocks
Superpro comfort diff bushes
Axis Hiro rims (copies) 8.5" & 9.5"
DJR rear spoiler.
Custom Engine & ZF Tune.
Monroe's have been fine mate. Kings are based on the goldie and recommended them. Plenty banged on that I'd regret the springs too - sagging etc. Well, after the initial settle in of 5mm they haven't moved. The rear did drop another 5mm ish after I fitted the tow pack however which is to be expected. If I'd gone the SSL SSSL combo it would've been a mistake. Time over? Hmm, maybe higher end like koni's. That or if had the coin, Tein coilovers.
The car will be on display at the All Ford Day at Willowbank on 20th July with hopefully the DJR spoiler fitted as well. The bonnet is getting a respray and car detailed up so will load some photos from that day.
  • MattyP
  • Cruise Control
  • Member For: 12y 9m 26d
Nice
Do you know your hub to guard measurments?
I'm about to order some king springs to go with my Koni reds I picked up cheap
Just trying to work out an appropriate amount of low
I've got 348mm fronts 335mm rears with SSL front and rear. Used to be around 340mm in the rear before tow bar. SSSL stuff the rear geometry so no good if you want it to handle still and not potentially hurt your drive shafts.
^^ SL is basically XR height - approximately 10mm lower. I reckon SSL would be your go but again, don't do the SSSL rear thingy that plenty do for looks reasons only.
I might have measured wrong but my ssl on all 4 gave me 352 front and 340 rear Bomber.
Wish mine was same height as your front..
Edited by BenDoCo
