  • Bronze Donating Members
  • Member For: 12y 1m 5d
absolutely brilliant
love seeing trailers like this
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 11d
Mate that is wild !!
Whats the go talk us through the build
yeah with Jet
build thread build thread
  • Carnage on the Garage Floor
  • Member For: 15y 1d
Well, goes something like this. I discovered this frame on a job that had a hilux extra cab tub on it that had been in an accident. Was in the owners way. Carton later, towing home. Grinder came out and buzzed the tub in half - off to tip. Had sourced another new hilux tub ready for $400 but said nup, gotta be Falcon. Rang my local dealer and as luck would have it they'd just delivered an XR with a tray and the owner didn't want the tub. Negotiated a 'very' reasonable price and picked it up the next day with brother-in-law and his brother. Measured everything up and cut 75x50x75mm long 2.5mm RHS mounts which were welded directly onto the frame under the ribs. This I knew would give me correct ride height - about 10mm lower than stock XR. The axle was too short and Expensive Daewoo pattern so ebay'd it for $50 - gone. Rubber had gone off on the XR (about 60% left) so bought two new rims and tyres. They went on the car, the others to the trailer. Calculated the axle length 70", which ended up 5mm in from the outer with the 9.5" ET40's and 275's. The frame was gal but painted it black. Four sets of hands and on she was lifted to the frame. Drilled my holes into the new mounts and rattled them on. To finish, I'm making a checker infill front panel and, fakey zort tips to match the car, lol. Going to fit a soft cover for now. Has an extended draw so tows perfectly and backs a treat. Total weight a shade under 300kg. 22kg on towball. GVM 750kg so can carry 450kg legally. I'm the President of the Gold Coast Performance Ford Club so it will mainly be used for club duties plus carrying my tools for the odd Saturday cashie. If anybody gets a tub and wants to build one I'll shoot the measurements.
Cheers, Bomber.
  • Like 2
sweet job....well done
hope the other club members up there appreciate your work
Had a slight no load idle pulse that would come and go. The boys had a couple of goes and thought we'd cured it but back it came. Anyway, the power steer switch crapped itself on the weekend and I replaced it tonight. As luck would have it - fixed both faults!
You can now get the switch separate - not the entire hose kit for like $265 trade. Switch cost me under $20 today ($19.36 to be exact). Don't get fleeced by somebody telling you otherwise.
