  • Member For: 14y 5m 26d
Completely misread that first post by Jetsnot. that's the gas model number and Bomber's model numbers are the sport!
Yea that ebay set for $720 is the one I'm going for. But extra $50 to get ssssl for the rear, $170 for front camber kit, $150 for rear eccentric offset bushes and $55 for pair of shortened bumpstops (all super pro parts)
$1145 all up and should get exactly what I want!
  • Carnage on the Garage Floor
  • Member For: 14y 11m 3d
The cat was hanging a bit low so had it modified today. The exhaust is perfect now - finally! The lowest part - at the cat - is 105mm now, up from 85mm. That should prevent anymore scrapes as I had touched a couple of speed bumps.
Edited by Bomber
  • Member For: 14y 11m 5d
Ordered the monroe shocks today so I will see how they go. If they suck I'm going to blame you Bomber lol.
  • Member For: 13y 10m 11d
Which cat back you using twin 2.5 or 3.5? How did they "modify" the cat? Mine still hangs a little low too at just over 90.
I'll take the blame but I'm pretty sure you'll be happy with them, lol. I'm still very happy with my King/Monroe combo.
David I've got the 2.5" twin xforce catback with the Venom bolt up cat. An exhaust shop cut some the length of the vertical section up to cast factory dump and re-flared the end so it would bolt up again. They then added a small piece on the horizontal so the whole thing fitted perfectly. The end result raised it 20mm at the front part of the zorst. My middle muffler has 120mm clearance, the front flange is 110mm and the cat 105mm.
If you have clearance to the floor, I suspect you could do similar also with your xforce dump.
  • 2 weeks later...
Car in at Ford for warranty repair today. Passenger side swaybar link had come loose. Recommend checking them.
  • 3 weeks later...
Nothing really new to report except the car ran awesome at Lakeside on Sunday. Oh, and I'm am fitting a new set of NGK iridiums when they arrive from the USA hopefully this week. $55 bucks to my door - gotta love ebay.
Hopefully Henz likes the stance now. Probably needs moar low :)
PS. Was pulling about 2 hungie when I checked once where that photo was taken on the dogleg of the main straight. Um, need brakes - bottom was flexing trying to pull the barge up, lol.
Edited by Bomber
  • Member For: 17y 25d
Holding yourself to the seat with your sphincter?
Looks good.
