  • Carnage on the Garage Floor
  • Member For: 15y 14d
Well, I think the Haltech Elite 1500 won't be getting the nod. Found out yesterday you've got to run a few plugs ins to make it work - particularly if wanting to run Ford coils. It starts to get real expensive.
So, I'll go with the factory ECU with PATS disabled. You can still run the IQ3S dash via the OB2 port so all good.
  • Moar Powar Babeh
  • Member For: 19y 8m 2d
Get the latest model fg turbo pcm you can find.
Edited by Ralph Wiggum
  • 2 weeks later...
Why the latest model pcm?
De-burred and ready for the -10 fittings to get welded on then off to the powercoaters
  • Like 2
  • 3 weeks later...
Being a Plumber, I'm going to have a crack at fabricating the cooler pipes myself then get them welded up.
Running eboost also means I can delete the factory boost sensor which will make the cold side pipe pretty simple. I'm running 63mm tube so will run a stepped down 90 degree silicon elbow straight off the FG throttle body. A turbosmart vee port pro will be attached probably just after the pipe passes through the inner guard. I was hoping to hide it behind the front bar but I don't have the height.  In front of the wheel behind the inner guard can be done, but I don't really like the idea of it being there. It's not like the thing will be out in the rain but I'd rather keep it in the engine bay.
From there, it will go back up to BPR fabrication for the custom 4" dump and waste gate plumbing.  After that, the plan is to paint the bay then fit the engine and assemble what I can. In a perfect world, I'd like to have it running before painting the rest of the car but I don't know if that's viable given the amount of wiring required - see how we go.
  • Like 5
  • 4 weeks later...
Ok, turbo decision time. Was keen on a gen1 GTX3582r but garrett are playing silly buggers with supercore prices. Can get a MTA 750X for under $1500 or, MTQ can build me a 66mm jobbie with a genuine garrett CHRA, anti-surge comp cover ect for same money basically. Keep in mind, I have vbanded 1.01 hi mounted goodness cranking it with 50mm pro gate bleeding off.  400rwkw remains the goal. My preference is still the gen1 GTX but I'm not paying 2k for the superceded model.
Thoughts on the 66mm jobbie?
  • MattyP
  • Cruise Control
  • Member For: 13y 21d
Ill let you know how I go Mick,
I Plan on going over to the 66mm Mamba gtx3584r, For the price its hard to pass it up
How much do garrett want?
  • Dropping a turd
  • Member For: 17y 6m 28d
Expand
V- band rear. Has to be borg warner. If starting from scratch.
Edited by arronm
I've already got the vband to vband single entry garrett housing arronm.
