Box stock T. Member 1,384 Member For: 10y 1m 7d Posted 27/12/16 12:34 PM Share Posted 27/12/16 12:34 PM Best of the old and new. Turbo barra with a tricked up C4 backed up by a bullet proof 9 inch I would be guessing. Brings back memories of my XY ute 2 pac with with turquoise grille and highlights 351 C4 9 inch with 4.11's detroit locker. Memories..... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1626531 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 3d Gender: Male Location: Gold Coast Posted 27/12/16 11:54 PM Author Share Posted 27/12/16 11:54 PM On 27/12/2016 at 12:02 PM, JETURBO said: The old C4 hey, should take a mild beat up ok Expand Will get it done. Billet 4 gear roller front planet set, billet c servo 2nd gear, chrome moly forward ring gear hub, hituf input shaft, roller thrust bearings, 6 clutch top gear, torque power bellhousing. The trans builder is extremely well respected. He has many living happily behind Barras. Just couldn't do the two speed thing and TH400's are heavy and the tunnel would have required a massage and custom cross member. This will bolt straight up. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1626557 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 3d Gender: Male Location: Gold Coast Posted 06/01/17 02:25 AM Author Share Posted 06/01/17 02:25 AM (edited) Well, after nearly getting shafted on what was meant to be a 30k FG XR6T MK2 engine - that turned out to be a green top with a lick of red paint, I'm considering my options. The BA mock up dunger in the car at the moment was intended for scrap eventually but... I have access to some FG Turbo rods and was thinking maybe just put some half decent slugs on them. It's done 170k so hopefully would just take a quick hone. Either go full povo and just check piston and rods weights or, get the rotating assembly rebalanced. Clean the head up, fit PAC springs, head studs, oil pump gears and new guides. Bare bones basics. Given the amount of people I see using $200 N/A engines in X series conversions now with low boost, I'm sure a freshened up one with FG rods and say Ross pistons would get it done. 400rwkw is seriously as much as I want or need to run in the old girl. My question to those that really know these engines, is what's really the difference between N/A and Turbo heads and Cam profiles? I've been told something about the valves but haven't got a definitive answer. Found this interesting too: Conrods and PistonsQ: Do I need to rebalance my engine if I fit Atomic conrods to my XR6-T? A: As the engine is an inline configuration, the conrod and piston weights are not a function of the balance factor of the engine (as they are in a V configuration engine), so they can be installed without rebalancing the engine. Edited 06/01/17 02:27 AM by Bomber Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1627571 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,497 Member For: 17y 1m 4d Gender: Male Location: Melbourne Posted 06/01/17 02:30 AM Share Posted 06/01/17 02:30 AM cams I'm not sure about (pretty sure they're different, but maybe not ) , but the head is the same between N/A and Turbo except inconel exhaust valves in the BA. Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1627572 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 17d Gender: Male Location: Perth Posted 06/01/17 03:04 AM Share Posted 06/01/17 03:04 AM Ba cams are different to Bf. The later are better. FG cams fall to bits...... With rods and pistons, just match weight to the lightest. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1627576 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 3d Gender: Male Location: Gold Coast Posted 06/01/17 03:20 AM Author Share Posted 06/01/17 03:20 AM Do you spin the crank up again if changing rods and slugs? Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1627582 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 3d Gender: Male Location: Gold Coast Posted 15/03/17 07:44 AM Author Share Posted 15/03/17 07:44 AM Have sourced a decent BFII Typhoon engine for the nugget 1 Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1634470 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,497 Member For: 17y 1m 4d Gender: Male Location: Melbourne Posted 15/03/17 08:06 AM Share Posted 15/03/17 08:06 AM so soon? Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1634471 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 3d Gender: Male Location: Gold Coast Posted 19/03/17 12:35 AM Author Share Posted 19/03/17 12:35 AM (edited) The purists aren't going to be happy but all going to plan, I'm hoping to run the Haltech IQ3 Street display. I've chopped into a spare facia to get an idea of how I'd make a flat area for the panel, plus create space for other gauges such as eboost2, start button, etc. After doing the mock-up in cardboard plus putting some photos to scale on it, I'm happy with how it would look. I'll now get an aluminium infill made with the intention to glass it in then blend in and refinish as close to factory (in black) as possible. I'll back mask and do some chrome highlights around the border etc. The original warnings (park brake and so on) I'll probably leave dead as the IQ Street has them incorporated. Edited 19/03/17 12:36 AM by Bomber 6 Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1634719 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,497 Member For: 17y 1m 4d Gender: Male Location: Melbourne Posted 19/03/17 12:41 AM Share Posted 19/03/17 12:41 AM loving the progress updates, bomber! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/76642-in-the-club/page/141/#findComment-1634725 Share on other sites More sharing options...
