Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 8m 17d Gender: Male Location: South West QLD Posted 06/01/13 05:58 AM Share Posted 06/01/13 05:58 AM Yeah that's really odd.. Cause to get rid of the light they have to clear the codes.. Unless Bionic turns up and sheds more light on this.. My experience with ford was they always told me the code and what it meant.. Then admitted they have no idea why it was throwing the code. Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1345299 Share on other sites More sharing options...
mrxd Member 74 Member For: 12y 6m 9d Gender: Male Posted 06/01/13 06:34 AM Share Posted 06/01/13 06:34 AM On 06/01/2013 at 5:55 AM, stretch4660 said: only took it to ford because I can't do the code check myself because I dont have the gear. I wont make that mistake again, $200 for nothin' cheers Ford$20 if you have an android phone. $5 for the torque app and $15 for an ELM327 bluetooth OBD2 interface Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1345309 Share on other sites More sharing options...
stretch4660 Member 122 Member For: 12y 3m 26d Posted 06/01/13 08:01 AM Share Posted 06/01/13 08:01 AM I never even thought of that mrxd, I'll check it out, thanks Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1345338 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 4m 19d Gender: Male Location: WA, Perth Posted 09/01/13 02:12 AM Share Posted 09/01/13 02:12 AM On 12/12/2012 at 2:12 PM, ruppet said: Got 28,000klm on my 6/12 xr6t ute only issue is a bad diff whine between104-115kph, just got to find sum time to take it in for warranty .I got the exact same problem, but mine is when I am driving at 73-78km/h. I get this humming or whine sound coming from the back.I have taken the car to 2 different ford dealers and every time it is the same thing. the tires are the problem.BS is all I have to say. I think it may be the diff, but it is only there when you turn on cruise control at those speeds.One of the dealers said it is the drivetrain. it just seems to be getting worse and worse. I have a manual. On 26/12/2012 at 12:00 PM, robbay91 said: this probably isnt really an issue but do the auto fg's get axel tramp when u floor it? or is it only manuals with this problem?If you have the TC on and flooor it and the wheels spin, the TC will brake and stop the spining, you then get the tramp.Try it with the TC off and see if you still have the issue. Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1346881 Share on other sites More sharing options...
zexxr8 Donating Members 28 Member For: 13y 1d Gender: Male Posted 09/01/13 02:20 AM Share Posted 09/01/13 02:20 AM The diff whine seems like a common problem. Mine is really bad coming back from 100 down to 90 and that's on diff number 3 with 4500 kms on the clock. Now they want the ute to take out the diff and send it to Adelaide to be repaired so hopefully its not off the road for more than a week. Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1346882 Share on other sites More sharing options...
stretch4660 Member 122 Member For: 12y 3m 26d Posted 09/01/13 02:40 AM Share Posted 09/01/13 02:40 AM Just called my mechanic, car was in for rough idle/hunting at idle. He said when they put it on their scan tool there was about 20 codes to do with throttle body, cam timing and MAP/boost sensor issues, He also said there is a sensor or group of sensors that has like coolant temp, MAP and boost sensing all in the one sensor. Any of the guys with good knowledge of the FG xr6t able to shed any light on this and if anyone else has had similar problems..? Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1346890 Share on other sites More sharing options...
robbay91 Member 68 Member For: 12y 8m 30d Gender: Male Posted 09/01/13 12:45 PM Share Posted 09/01/13 12:45 PM if a cars been tuned by a crap tuner, and you take it to a good tuner to retune it, will it be ok? or still be crap Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1347171 Share on other sites More sharing options...
stretch4660 Member 122 Member For: 12y 3m 26d Posted 10/01/13 02:33 AM Share Posted 10/01/13 02:33 AM She aint been tuned, stock as a rock, but yes if you take it to a crap tuner I would expect the outcome to be crap. Spending a little more to go to a reputable tuner would be the best idea straight off the bat, save the grief Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1347342 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 11m 7d Gender: Male Location: Gold Coast Posted 11/01/13 08:47 AM Share Posted 11/01/13 08:47 AM Have noticed lately that when I take off from lights etc I hear a short water rush sound coming from under the glove box area. It sounds like something is emptying from the air con. Have checked the overflow to make sute it's clear and that seems ok. No water is entering the car or anything. Any ideas? Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1348014 Share on other sites More sharing options...
stretch4660 Member 122 Member For: 12y 3m 26d Posted 11/01/13 08:51 AM Share Posted 11/01/13 08:51 AM Air in your heater lines than run behind your glove box for the cabin heater, garuntee if you take it to ford they will tell you there is nothing they can do, which is pretty much right. Put a/c to heat and drive round for a bit, then park it till the engine cools, check coolant level is correct, that's about all you can do Link to comment https://www.fordxr6turbo.com/forum/topic/76592-known-issues-fg-xr6t/page/8/#findComment-1348017 Share on other sites More sharing options...
