Earls Turbo Line Kit
gkors
  • Member For: 13y 6m 17d
Hi,
Just got an earls kit to put on a mk2 BF.
Trying to figure out how it goes in and bypasses the original filter :blush:
Will need to get some new copper washers from fraud.
The banjo end goes on the turbo? the other end has what looks like heat sheilding so would it screw straight into the turbo not a banjo fitting?
Banjo ends on both ends of the original one.
Help
Edited by gkors
  • Member For: 16y 7m 8d
There's an arrow on the filter. Need to point to the turbo. When you take the old one out you will see the mesh in the bolt that you need to remove. Make sure you use lock thread wherever you can
thanks guys, just didn't want to get it pulled out and find it won't screw into the turbo and needs a banjo fitting.
Will get some hydraulic locktite.
Whats the best way a few rubber clamps bolted to the front of the block to hold it up not too keen on zip ties.
I can see this is going to create a lot of swear words jesus that's tight in there.
  • Member For: 16y 11d
anyone know where I can get a banjo fitting for these kits...attempted to put gauges in today and stripped the thread on the banjo...apparently 14.5mm (9/16) -4 banjo fittings are f*cking impossible to get???
  • Member For: 13y 5m 11d
wheres everyone buying these earls line kits from ? I saw the ones gktech are selling they the same ? is it worth buying one ?
The cheapest place is Ebay for the earls line
Sent from my HTC Desire using Tapatalk
