CBXRT Banned 643 Member For: 14y 7m 15d Gender: Male Posted 16/08/11 01:33 AM Share Posted 16/08/11 01:33 AM (edited) Looking for some help guys hopefully I only have my old BA with 170k - still goes really well though and sounds very meaty with my exhaust mods. Suddenly, it sounds like crap (half the note and 'thin'/weak sound), quite sluggish on acceleration (down approx 25%) with strange rpm fluctuations, and worst of all, strong fuel smell in the cabin after driving. (not rotten eggs, definite fuel smell like at a service station)My injectors were cleaned 12 mths ago, but one place reckon they would need replacement with maybe valve springs to fix the problems, and $1200 thanks. I questioned it with another workshop as it sounded wrong/expensive, and a different place said there is no way it would be injectors, it is instead the fuel pump and pressure - sounded better.Any ideas guys? Would either of the above failures cause all those symptoms as they have all happened at once? Thanks very much for any advice on which one to go to - its a pretty routine/boring matter sorry, but I've wasted money before on my car when workshops get it wrong and perfectly OK parts are replaced for no reason.......very frustrating! Edited 16/08/11 01:37 AM by CBXRT Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/ Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 2m 11d Gender: Male Location: Victoria Posted 16/08/11 02:53 AM Share Posted 16/08/11 02:53 AM 2 more possibilities...Blocked fuel filter.Blocked or broken cat. Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1133402 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 10m 18d Gender: Male Location: Zombie Birdhouse Posted 16/08/11 02:59 AM Share Posted 16/08/11 02:59 AM I reckon collapsed / blocked cat or fuel filter as well Cat IMO first as your getting fuel smell Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1133403 Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 7m 15d Gender: Male Posted 16/08/11 05:57 AM Author Share Posted 16/08/11 05:57 AM (edited) Thanks guys, much appreciated.I would think the mech should have picked up a blocked fuel filter (surely!), but I am taking it to the second place on Thursday as the injector prognosis simply doesn't sound right to me. I will also give them a heads up of the other potential issues as you guys have provided above.....Thanks again Edited 16/08/11 05:58 AM by CBXRT Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1133438 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 14d Gender: Male Location: Perth Posted 16/08/11 06:08 AM Share Posted 16/08/11 06:08 AM +1 to previous comments. Dont suppose you know anybody that would have an infrared temp gun (know any body with RC Aircraft or Cars) if you can access one take the car for a run and then check the temp either side of the cat. A large disparity in temps would indicate a blocked cat. Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1133439 Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 9m 15d Gender: Male Location: Perth, WA Posted 16/08/11 06:11 AM Share Posted 16/08/11 06:11 AM Fuel filter is $10. good idea to change them every second service so do it regardless.If your cat section is stock BA (you mentioned exhaust mods), find yourself a BF factory cat and bolt that in. You will need the whole cat section from cast dump to the cat-back flange. You should be able to pick up a good used one for $50-$100. Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1133440 Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 7m 15d Gender: Male Posted 17/08/11 07:57 AM Author Share Posted 17/08/11 07:57 AM (edited) Thanks again lads, have an update. Idiot me didn't realise that when I had my mower in the back last weekend it spilt fuel EVERYWHERE in and under the carpet, so the smell was just that..... The sluggish acceleration, refusal to accelerate hard, and exhaust note issue remains (now its only like a V6 commo - and like its blowing bubbles rather than "cracking" like it used to.... ) - the engine also drops from 2,000/2,500rpm to 1,000rpm in an absolute instant on back-off, like its an engine cut-out......I changed the plugs, cleaned injectors and replaced all filters only 4 mths ago upon similar symptoms as the above (which worked but cost 1K), so I'm thinking it might simply be that again??? Must be something wrong if that's the case to foul plugs and get dirty injectors in that time????Anyway, thanks again all, much appreciated.ps: Luke, no I don't know anyone with that gun. You never cease to amaze with the gadgetery you are aware of - I have never even heard of 99% of the things you suggest!!! ha ha Edited 17/08/11 08:03 AM by CBXRT Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1133842 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 2m 11d Gender: Male Location: Victoria Posted 17/08/11 08:44 AM Share Posted 17/08/11 08:44 AM Idiot me didn't realise that when I had my mower in the back last weekend it spilt fuel EVERYWHERE in and under the carpet, so the smell was just that..... The sluggish acceleration, refusal to accelerate hard, and exhaust note issue remains (now its only like a V6 commo - and like its blowing bubbles rather than "cracking" like it used to.... ) - the engine also drops from 2,000/2,500rpm to 1,000rpm in an absolute instant on back-off, like its an engine cut-out......My money is still on the cat. Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1133860 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 10m 19d Gender: Male Location: Broady, Melbourne Posted 18/08/11 12:28 AM Share Posted 18/08/11 12:28 AM I had the same symptoms. The cat de-laminated and lodged itself (almost fully in-tact) in the rear muffler. Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1134044 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 14d Gender: Male Location: Perth Posted 18/08/11 12:36 AM Share Posted 18/08/11 12:36 AM Thanks again lads, have an update. Idiot me didn't realise that when I had my mower in the back last weekend it spilt fuel EVERYWHERE in and under the carpet, so the smell was just that..... Hope you dont smoke! Link to comment https://www.fordxr6turbo.com/forum/topic/76496-fuel-pump-or-injectors/#findComment-1134048 Share on other sites More sharing options...
