fordkid Donating Members 46 Member For: 13y 9m 18d Posted 15/08/11 09:37 PM Share Posted 15/08/11 09:37 PM Hey guys I got a 06 bf mk2 xr6t ute, I am fitting wheels and looking to lower the front about 25mm and the rear 40 mm.Can anyone give me an idea on how much the fronts will camber in? Also Will I need a camber kit to reduces the amount of negative the lowering causes?Cheers Link to comment Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 8m 18d Gender: Male Location: Perth NOR Posted 15/08/11 10:14 PM Share Posted 15/08/11 10:14 PM (edited) Yes you will.Probably end up with best part of -2deg .Depends on the amount of camber up front you have whether only shims are required or the full camber/caster kit. Edited 15/08/11 10:23 PM by wa g6et Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 3d Gender: Male Location: Christchurch, New Zealand Posted 15/08/11 10:52 PM Share Posted 15/08/11 10:52 PM I have a 07 BF2 xr6t ute and it is lowered with king springs in the front 40mm drop and reset leaves rear 60mm drop and the camber change wasnt even worth worrying about. Just do the lowering and then see how bad it is, if need be then get the camber kit otherwise dont worry. Link to comment Share on other sites More sharing options...
Mr Man Mad Scientist Member 816 Member For: 20y 2m 23d Gender: Male Location: Vic Posted 16/08/11 08:54 AM Share Posted 16/08/11 08:54 AM Each vehicle is different, I lowered mine of SL fronts and it was at least -2deg camber, so I put a camber kit in it. I've heard of others not needing one though... Link to comment Share on other sites More sharing options...
SHO-247 Member 77 Member For: 14y 4m 13d Gender: Male Location: South Australia Posted 20/08/11 12:51 AM Share Posted 20/08/11 12:51 AM how much are camber kits? easy to install? Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 3d Gender: Male Location: Christchurch, New Zealand Posted 20/08/11 05:57 AM Share Posted 20/08/11 05:57 AM At least a couple hundred but someone should come along with a proper price. Senna_T might be the man to talk to, you should PM him. Link to comment Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 8m 18d Gender: Male Location: Perth NOR Posted 20/08/11 06:15 AM Share Posted 20/08/11 06:15 AM Depends if you can get away with just using shims or you need a full kit.Kmac Caster KitsShims come in sets, usually a good suspension shop will have the correct ones on hand. The Kmac kit requires a bit more work, couple hours labour. Link to comment Share on other sites More sharing options...
Cheaty McCheats Totally not a Cop Donating Members 821 Member For: 14y 27d Gender: Male Location: Melbourne Posted 21/08/11 01:32 AM Share Posted 21/08/11 01:32 AM Installed pedders coilovers on my BFII and got about -2 on the fronts, think it was around -0.5 on the backs.I don't care about tire wear, I like stance Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 3d Gender: Male Location: Christchurch, New Zealand Posted 21/08/11 05:16 AM Share Posted 21/08/11 05:16 AM Being a ute the rear stays at 0 which, (as long as you have same size tyres all round) means you can put the fronts on the rear to square them off again. Link to comment Share on other sites More sharing options...
