nathanway Member 106 Member For: 13y 4m 24d Gender: Male Location: townsville Posted 08/08/11 09:12 AM Share Posted 08/08/11 09:12 AM an idea what if you pull the turbo off pulled it apart took a grinder to the cold side blades and grinded them off so theres no core than get the wastegate and jam it open put it back on and than only rev the car to 2000rpm/ boostthreshold as not to throw the computersaying that im a carpenter not a machanic Link to comment Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 1m 7d Gender: Male Posted 08/08/11 10:01 AM Share Posted 08/08/11 10:01 AM (edited) Any idea why the turbo blew? Turbos should last a very long time in these cars unless very unlucky. I would be checking that first, no point getting another one just for the same thing to happen? (tuned poorly, too much boost, etc etc) Edited 08/08/11 10:02 AM by CBXRT Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 7d Gender: Male Location: Perth Posted 08/08/11 10:09 AM Share Posted 08/08/11 10:09 AM an idea what if you pull the turbo off pulled it apart took a grinder to the cold side blades and grinded them off so theres no core than get the wastegate and jam it open put it back on and than only rev the car to 2000rpm/ boostthreshold as not to throw the computersaying that im a carpenter not a machanicWith all due respect mate, please stick to carpenty..... Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 12d Gender: Male Location: Christchurch, New Zealand Posted 08/08/11 10:11 AM Share Posted 08/08/11 10:11 AM If you do that I want to see pictures! Link to comment Share on other sites More sharing options...
ALF05T Member 453 Member For: 17y 11m 16d Gender: Male Location: Sydney Posted 08/08/11 09:54 PM Share Posted 08/08/11 09:54 PM The insfucient diameter of the oil lines. There have been many blown turbos with worn out bearings due to not enough oil supply.Seems to be more of a problem at higher boost due to turbine spinning fster and needing more oil,.my 2cAlf Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 12d Gender: Male Location: Christchurch, New Zealand Posted 08/08/11 11:29 PM Share Posted 08/08/11 11:29 PM (edited) Id be looking at the filter rather than the oil line size. If it was the diameter of the line mine would be stuffed by now along with alot of others.Check out this thread, LINK Edited 08/08/11 11:32 PM by Wenier Link to comment Share on other sites More sharing options...
ALF05T Member 453 Member For: 17y 11m 16d Gender: Male Location: Sydney Posted 08/08/11 11:54 PM Share Posted 08/08/11 11:54 PM good point Link to comment Share on other sites More sharing options...
nathanway Member 106 Member For: 13y 4m 24d Gender: Male Location: townsville Posted 09/08/11 08:29 PM Share Posted 09/08/11 08:29 PM would it work do u understand what I ment though just remove all of the blades on the broken wheel so no more could break off, like a turbo with no compressor I reckon it would overspool to the max even with the gate forsed open probly explode Link to comment Share on other sites More sharing options...
ALF05T Member 453 Member For: 17y 11m 16d Gender: Male Location: Sydney Posted 09/08/11 09:51 PM Share Posted 09/08/11 09:51 PM I thin the balance of the core would be out of wack if you pulled the blades off, they spin at a very high rpm so in my opinion I would not do that.Save the coin and get a replacement turbo core before driving your car otherwise you may do more damage.Good luck Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 7d Gender: Male Location: Perth Posted 10/08/11 12:39 AM Share Posted 10/08/11 12:39 AM would it work do u understand what I ment though just remove all of the blades on the broken wheel so no more could break off, like a turbo with no compressor I reckon it would overspool to the max even with the gate forsed open probly explodeI understand exactly what you mean 10/10 for thinking outside the box, but this would only work in an emergency situation. Your risking engine damaged If/WHEN the core lets go.It would overspeed the shaft to the point that it would fail, you would then loose wind up pumping coolant into the sump and oil out the exhaust...Long story short. Dont do it Link to comment Share on other sites More sharing options...
