SMURF6 Jamie Donating Members 380 Member For: 16y 6d Gender: Male Location: Maroubra, Sydney, NSW Posted 16/08/11 12:45 PM Share Posted 16/08/11 12:45 PM I have had the same problem for a year.. No one can help me either. Might bring up the gap issue when I get my car re-tuned in a month. See what happens ay Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 13y 6m 8d Gender: Male Location: Victoria, the place to be defected. Posted 16/08/11 04:17 PM Author Share Posted 16/08/11 04:17 PM got a 2nd hand abs module for 280, getin it instaled today, hope it fixes it :( changed my sparks just incace but no prevale...dynomotive rekon these modules do this some cars they wrked on, throws out codes but nothin 4 a module..stupid thing, fingures crossed. Link to comment Share on other sites More sharing options...
Moose Member 185 Member For: 16y 9m 25d Gender: Male Location: Ipswich, QLD Posted 17/08/11 12:03 AM Share Posted 17/08/11 12:03 AM Yeah my problem seems all fixed from just the spark plug gaps! Speedo fine, no lights come on etc. If it comes back, I'll check my ABS unit, because the other bloke on this forum just replaced his ABS unit and bam! fixed! Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 9m 16d Gender: Male Location: Brisbane Posted 17/08/11 02:28 AM Share Posted 17/08/11 02:28 AM Moose didn't you mention elsewhere there was a faulty speed sensor as well? That would certainly explain the issues in this thread...can't see how spark plugs would be the cause of any of these symptoms Has yours been playing up since the snowies cruise Smurf? Wasn't that the issue then - a speed sensor had fallen out of the bracket on one of the front wheels? Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 13y 6m 8d Gender: Male Location: Victoria, the place to be defected. Posted 17/08/11 05:24 AM Author Share Posted 17/08/11 05:24 AM I just about had it, changed abs module, didnt make a difrence...code p1000 showing no one knows why or the cause, fml at the moment.. Link to comment Share on other sites More sharing options...
Moose Member 185 Member For: 16y 9m 25d Gender: Male Location: Ipswich, QLD Posted 17/08/11 05:37 AM Share Posted 17/08/11 05:37 AM (edited) Yes there was a speed sensor unplugged (or not clipped properly) but that only solved the speed sensor issue, it was still lighting up the dash and killing the speedo etc, the fix to that was checking the spark plug gap!Toxic07 - I feel your pain, I really do - I hope it gets sorted sooner rather than later! Edited 17/08/11 05:39 AM by Moose Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 13y 6m 8d Gender: Male Location: Victoria, the place to be defected. Posted 17/08/11 05:50 AM Author Share Posted 17/08/11 05:50 AM thanks mate, I got a mechanic goin to do a real time scan to see wat pops up, last thing I can do and afford now.. Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 13y 6m 8d Gender: Male Location: Victoria, the place to be defected. Posted 17/08/11 06:21 AM Author Share Posted 17/08/11 06:21 AM real time scan showed comunication fail when on high load, now gona add earth to ecu and batt.. Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 13y 6m 8d Gender: Male Location: Victoria, the place to be defected. Posted 17/08/11 07:29 AM Author Share Posted 17/08/11 07:29 AM and it did nothing..what in the f.. Could this be Link to comment Share on other sites More sharing options...
SMURF6 Jamie Donating Members 380 Member For: 16y 6d Gender: Male Location: Maroubra, Sydney, NSW Posted 23/08/11 08:50 AM Share Posted 23/08/11 08:50 AM Moose didn't you mention elsewhere there was a faulty speed sensor as well? That would certainly explain the issues in this thread...can't see how spark plugs would be the cause of any of these symptoms Has yours been playing up since the snowies cruise Smurf? Wasn't that the issue then - a speed sensor had fallen out of the bracket on one of the front wheels?Ye since the last cruise...I ended up passing a battery world the other day and felt like getting my battery checked. It's the original from factory 2 years ago..They measured it and only half the capacity was left which apparently causes faults. I ended up putting in a dry cell and It starts up perfect and haven't had any issues yet. Apparently before it was putting strain on the alternator which causes the volts the alternator produces to drop causing errors and faults.For example even now if I go to take off on a hill and release the clutch to early and the car almost stalls it I still get errors and faults for abs and all sorts of crap.. It has to do with voltage drop. Link to comment Share on other sites More sharing options...
