  • Member For: 18y 28d
Welcome to the forum,
What did you get done to make the power?
  • Member For: 14y 8m 1d
Another addicted car nice, tonyv had his done there to. If you don't mind me asking what is the price of a the built motor? see if it's worth going atomic or not.Good results and what dillz said what mods.
  • Member For: 13y 10m 24d
Started with second hand block
Sonic test,bore and home,deck,Chen clean,line hone,crank grind,engine balance
Muhl pistons/hasting rings
Big end and main bearings
New timing chain and tensioner
Comedic head gasket and full gasket set
Arp head studs
Oil pump gears
New injectors
Turbo repairs(had frachers)
Waste gate enlarged
New sct flash tuner
Head was mod all ready,had it repaired/check and decked
It's runing 15 psi
And cost around $11500 tuned
New sct
Glad your happy with it, so with the built motor you goung to turn the wick up on it for more power. or you happy with what you got. So the car was tuned before you got it?
