Ba Xr6T Does Serious Missfire When Pressed Hard
Xr6trbooooo
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
  • Member For: 17y 6m 6d
XR6TRBOOOOOOO
What is the car doing, a little more detail would be good ,doe's it rev out in 1st and then die ,or just miss ,it could be any of the things suggested,if the basic things like plugs ,coils, fuel filter don't fix it ,take it to decent ford dealer and get them to diagnose it for you,might save you some money.
Mine was dying like that and it was the wastegate actuator. good luck .....J K....
  • Member For: 13y 8m 12d
Hey turbomick ,,, mate I don't know abt IC cos it was already on when bought the car and it was doing thAt time....
NEEDFORSPEED car has got 129k's so should I change coils....????
Hey JK.... yeah mate car goes good unto about 3000-4000rpm but then It kinda starts engine braking in trucks .. Or something like traction cntrl.. It cruises perfct but when press go pedal down to floor ... It just doesn't wanna go....
HEY GUYS CAN ANYBODY TELL ME UPTO HOW MANY REVS your CARS GOES WHEN ON NUETRAL OR PARK.... on ful throtel
Thanks guys
  • Member For: 15y 2m 18d
Well 129K is high enough for coils to be breaking down so you probably need to replace them, they will also show up when you go for full throttle and load the engine up you wont get a good enough spark as the coil isnt performing.
I dont rev my car in neutral to full throttle so I wouldnt worry about that, plus the ecu probably has a low limit so if someone does they dont break the motor.
  • Member For: 13y 10m 27d
Thanks guys
where in vic are u ?
I wouldnt be reving the crap out of it when its in nuetral or park . even if it wasnt missing and farting around .
  • boosting
  • Member For: 18y 9m 15d
Same thing happens to my car. Feel for ya mate.
I have NFI what it is :( Fraud couldn't pin point it. I have no mods except a pod filter and pipe.
Going in for a service soon
cars got 125kms.
  • Im the one and only
  • Member For: 20y 2m 28d
I have a BA with 130k on the clock.Same symptoms but I replaced and GAPPED the plugs and all is sweet.Make sure you check the gaps as mine were all over the joint and was causing the spark to blow out.
