353 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Member For: 12y 1m 17d
^peak power at 3500 rpm doesn't sound right unless you did a turbo Diesel engine swap
I made 315rwkw in 33 degree ambient temp with 15psi
Plaz 800hp cooler, aftermarket airbox, id1000 injectors and venom hi flow cat
  • New Member
  • Member For: 10y 4m 13d
Elite Automotive
Pretty happy, would've liked to get the magic 300. It's was a typical 37 degree day at about 80% humidity in Brisbane, illegal weather.
Next up will be finishing the exhaust, fuel pump etc, turbo probably the 82R.
I do have some damage on the cams and will need to be replaced. Is it worth going bigger or just keeping the standard size cams?
  • loitering with intent
  • Member For: 21y 7m 24d
Elites dyno reads a little low compared to some others.
Thing is not to get hung up on a number as a dyno is a tuning tool.
It's how it drives that matters
  • Member For: 11y 10m 6d
37 degree day definitely isn't going to help either so you may well produce a fair bit above 300 in ideal temps. Although Brisbane climate is always pretty humid.
Congrats either way, not many lions keeping up with that
  • Too heavy needs boost
  • Member For: 11y 8m 6d
Mine went 300.8 in a thousand degree shed. Ask butt plug. He tuned it.
